I have luck with setting the output bias current. You do that with a resistor to the negative supply. This will give you the offset. Without the bias current, you are dealing with a dead opamp. But of course you will still get the output voltage by virtue of the total current going around the opamp. Be mindful of the impedance. I have found that in order to get the ouput current right and the impedance you need this resistor to the negative supply. If you don't operate the opamp the way it was intended, you won't get the change in input current. The inputs will sit there at ground and all the current still goes around the opamp. I think what happens is that the beta of the output current transistor, the top one, becomes too high and the feedback resistor looks to be too large. The feedback resistor, after all, is really a collector resistor as seen by the interior of the opamp circuit. The base resistor is seen an emitter element from the viewpoint of the other input that is divided by beta.
