Hi again. I'm not clear on how deeply you want to dig into the electronics, but you can get a great initial view of much of the internals in two steps:
When you're all done your investigation and putting the cover back on, I've found I had to take extra time & effort to make sure I lined up the screw holes on the cover accurately so that the back cover can be snuggly replaced with all 6 screws going in as deeply as they're designed to do.
- After unplugging the chair, stand behind it and gently flip it on its front so that the back of the chair is facing your ceiling. The chair is heavy, so you'll want to get the assistance of an additional person to prevent it from hitting your floor too hard.
- Once the chair is flipped and the back is facing the ceiling, there are 6 screws you can remove to lift off that cover to open up the back.
