Proschuno11
- Jan 3, 2026
- 6
- Joined
- Jan 3, 2026
- Messages
- 6
Greetings, I'm designing and building a Linear PSU that takes two AC inputs which it rectifies and filters them into a split supply consisting of LM317's and an LM337, each current boosted by a pass transistor. What I'm wanting to know is if the star grounding scheme I'm attempting would be sufficient; Blue colored, the entire rectangular plane surrounding the filter caps is all Ground, then each circuit surrounding the regulators is grounded on their own bus which then reaches the bit of ground plane nearest them. The 6 pin footprint to the most right will accept a cable with a molex connector which will provide the two positive voltages and the one negative voltage, along with ground, which will be a jumper running from this connection to another hole exactly between the caps as shown with the magenta . I'm planning on using this with Eurorack modular synthesizers, providing them with +12V, +5V, and -12V. I'm expecting to draw 3 amps from the +12V line, and about 1 amp each for the +5V and -12V lines.
I'm wanting to know
1. If this is even worth my time to use a star ground or if I should be using a ground plane
2. If so does what I have provided seem like an effective scheme?
I'm wanting to know
