superuser726
- Mar 8, 2026
- 9
- Joined
- Mar 8, 2026
- Messages
- 9
I have a 2yr old JBL Bar 2.1 Mk2. It stopped working about 2–3 months ago and I've opened it up now to try to see what could be the problem.
When playing any audio from any source, it creates a very loud screech sound from the speakers. I have attached a video of the same.
It is only present when audio is being played. It gets louder if volume is increased, but if nothing is being played and volume is at 100, no screeching sound is there.
System sounds like the Bluetooth connected tune also make the same screeching noise.
Today I opened it up. There's a switch-mode power supply and it connects to the main audio board with one pair of wires. This runs at 23V.
Then at the audio board, there are four big ICs only:
I thought there would be some dedicated IC for the Class-D amp but there's nothing obvious on either side of the board and only those two chips have a heatsink on them.
I've attached a pic of the audio board. There's some white goo on the ALC1322 chips from the heatsink.
The notable SMD parts:
There's two four-pin outputs which are:
L,R Tweeter +ve, -ve and L,R Speaker +ve, -ve.
So total 8 speaker pins.
What all I've measured:
Another very notable thing I noticed was that when I ran the audio board without connecting the speakers, there was the same screeching sound but much fainter coming from the audio board itself.
Touching or holding the inductors would only barely reduce the volume of the noise.
Connecting the speakers would amplify this same noise about 10× as it would be coming from both the board and the speakers.
Please guide me on what to do next, as in what might be the problem and what I will need to do to fix it.
- ES8680FSB (DAC?)
- EP92A2S4 (HDMI ARC)
- 2x Realtek ALC1322 with heatsinks on both (Class-D amp and codec?)
- 8 inductors near output pins (220 µH)
- Around this, 5 electrolytic capacitors (220 µF 35V)
- Little to the right, 1 inductor marked 100 µH
- Near this, 2 × 220 µF 16V and one 100 µF 35V capacitors
- To the edge of the board there's a 220 µF 16V capacitor
- Voltage at the 5 capacitors is 23V
- On the capacitors next to the 100 µH inductor, it has 5V
- Resistance of speaker output + and - is 98kΩ
- Resistance of speaker output + and speaker output - both to ground is 48kΩ
- No ICs get very hot when I run it
- DC voltage across speaker output is 0.002V
