5013 - Component identification
Alex141
Aug 25, 2026
3
Hi everyone, I’m new here and found this forum via a Google search. I’m having trouble finding the datasheet for this component show in the photo; it’s a programmable DC/DC converter. In the circuit in question, it takes in 5VDC and outputs 3.2VDC. Could anyone help me identify it? Thanks in advance. Pin 4 in - pin 9 out - lead GND
GigHz
May 4, 2026
4
The 5 V input and 3.2 V output help, but pin 4 IN and pin 9 OUT alone probably aren’t enough to identify the exact part. If you can post a close-up of the marking on the component, that would be the best clue. A photo of the surrounding circuit would also help, especially the pins connected to resistors or feedback.
Delta Prime
Jul 29, 2020
2,995
Hello welcome to electronics-lab.
:)5013 DC to DC Buck converter.
Thermally enhanced small-outline integrated circuit (often called PowerPAD™ or HSOIC-8/DDA).Pins: 8 leads arranged in two rows of four with a flat metal pad underneath.
  • lm5013-q1.pdf
Delta Prime
Jul 29, 2020
2,995
Count the number of pins of the original chip and compare to the datasheet :(
5013 - Component identification​
Please accept my apologies for submitting the wrong component datasheet earlier. I understand that accuracy is critical for our transfer of correct information, and I regret any confusion this may have caused.
Alex141
Aug 25, 2026
3
Thank you for trying to help. Looking more closely, the output to the external MOSFET is on pin 7 and the FB is on pin 9 (2.5V). A photo of the circuit is attached. The brown wires are from the coil that I removed to visualize the entire circuit. And the logo really is indecipherable.
