0-20 (3A) and 0-40 (1.5)A Power Supply (Elenco)
inferno
Aug 30, 2004
10
Hello!!!
Here is a schematic that I want to modify...
I want the 0-20 (3A) to become 5A
0-40 (1.5A) to become 2.5A
Any suggestions?....
tnx!!!
xp-750.pdf
  • xp-750.pdf
inferno
Aug 30, 2004
10
Here is the schematic..
ante1
Jan 24, 2004
4,136
Hi Inferno,
You have to change the transformers and the rectifiers for a start. If we stop at this and see if you have space enough for these new bigger parts, and some reinforcements done to the PCB then we know if it
inferno
Aug 30, 2004
10
hello!.. i haven't buy this power supply.. i got the schematic somewhere on the net... i want to modify it so that it will produce more current... (read the pdf for more info on the original schematic) pls help me modify it....;) tnx!
Kevin Weddle
Feb 23, 2004
1,620
Boy! Isn't that a variable soup. I am confused about the switches. You can select 0-20 or 0-40? That doesn't make sense. But then again I not an expert on commercial power supplies. I don't think I could recognize short circuit protection if I saw it, but the fuse will work.
audioguru2
Apr 6, 2004
12,022
Hi Inferno,
You want to modify that PSU to do much more than it was designed for? You might as well select a PSU that does what you want.
Transformers, rectifiers, filter capacitors, number of output and driver transistors, heatsinks, resistors' power rating, etc., etc. Oh man!
surajbarkale
Aug 5, 2004
256
TEN MOSFETS :eek: Ante, can i reduce number of mosfets or better yet how meny IRF540 will i need? I think i am going to try this.
audioguru2
Apr 6, 2004
12,022
Hi Suraj,
A simple calculation shows that Ante's circuit has 60V input and 5A output, so each Mosfet dissipates up to 30W. If you use a 40V supply, you need only 7 Mosfets. Mosfets with a lower on-resistance such as the IRF5210 would need only 2 or 3 for about the same total cost.
It is hard to see in the schematic, but Ante's circuit uses P-channel Mosfets, because they must pull-up. Your IRF540 N-channel Mosfets pull-down, and cannot be used in this circuit.
ante1
Jan 24, 2004
4,136
Audioguru,
Yes 30W each but with 0V out @ 5A, how often do you need 0V? You have to explain why a lower RDSon is better in this linear circuit, I think the RDSon is not very significant when running a mosfet
audioguru2
Apr 6, 2004
12,022
Hi Ante,
You are absolutely correct that RDS-on resistance doesn't matter much in a linear circuit. I guess I have "switchers" on my brain lately.
But using fewer of the low RDS-on Mosfet IRF5210 is still true because they also have a much lower thermal resistance than your original Mosfets. In the original 60V circuit, 10 of your Mosfets are needed, but only 4 of mine. In the 40V one, 7 of yours, but only 3 of mine.
1000 posts? Good, then I'll win an LED!
ante1
Jan 24, 2004
4,136
Audioguru,
You made me worried there, for a while I believed you have lost it. ;D Lower thermal resistance is good though. The circuit also need some change of resistor values and omitting the zener diode to work on 40Volts. And the LED is purple! ;D
audioguru2
Apr 6, 2004
12,022
Thanks Ante,
But I'll have to swim nearly half-way around this planet to pickup the purple LED from Greece. And anyway I already have some purple ones that were shipped to me by mistake!
I have some HP "cool blue" and green ones that are wide-angle but still are blindingly bright.
Your power supply will have full dissipation when driving a high current into a short. A guy on another chat line was having trouble with his rocket-launcher ignitor. I think it was a paper-clip that he was trying to feed a few Amps through.
You could also use it to see how hot a 0.1 ohm, 5W resistor gets with 5A through it (only 2.5W), to see if it will char a PCB.
audioguru2
Apr 6, 2004
12,022
Hi Ante,
HP sold their LEDs manuf. to Agilent, but I think Fairchild makes them too.
Cool Blue (clear case) HLMP-CB30. The last 2 numbers are the angle.
Its datasheet:
http://we.home.agilent.com/cgi-bin/bvpub/agilent/reuse/cp_ReferenceRedirector.jsp?CONTENT_NAME=AGILENT_EDITORIAL&CONTENT_KEY=5988-5675EN&STRNID=03&LANGUAGE_CODE=eng&COUNTRY_CODE=US
Thanks for the avitar, but I dislike those shrieking megaphones. I'm still looking for something that is more refined.
Kevin Weddle
Feb 23, 2004
1,620
Has anybody ever tried connecting a resistor to the power supply through a MOSFET. If you set the VGS to maximum then you can get the power supply voltage at the drain. Then you can apply a signal through that resistor and the drain will hold it's voltage. So you can have a changing current with a constant voltage. I think it will work by changing the GM even though you really can't change the current without changing VGS.
audioguru2
Apr 6, 2004
12,022
Hi Kevin,
If you apply a Vgs of only 10V to a Mosfet, then it would be turned-on so hard that the drain would seem like it is welded to the source.
But if you apply a Vgs of just a few volts, then a Mosfet would be turned-on just a little, and would act like a constant-current source.
The only devices that I know of that can "hold its voltage" are a zener diode and a voltage regulator IC.
You are correct if you are talking about a P-channel Mosfet as in Ante's power supply. The Mosfet will be turned-on hard and "then you can get the power supply voltage at the drain".
But if you "apply a signal through a resistor" that you connect to its drain then of course the voltage across the resistor will change and its current will change too. The same thing will happen if you connect that resistor to any DC voltage including 0V.
Kevin Weddle
Feb 23, 2004
1,620
Doesn't that mean that the drain voltage will remain constant like a voltage source with the current changing with the signal.
audioguru2
Apr 6, 2004
12,022
That's right, Kevin. But since the Mosfet is turned-on so hard, it is the same as a 2cm piece of wire.
