0-30 Vdc Stabilized Power Supply
rufinus
Sep 4, 2006
19
And here what i measured: pin4 (both) -5.65v; pin6 u1 +11.32v; pin6 u2 0~27v.
LED goes on when there is a load and current pot is to minimum. Both Q4 seem to be ok.
audioguru2
Apr 6, 2004
12,022
Hi Rufinus,
What value and where in the circuit is the fuse that blew?
Your current regulator is not working properly. It is supposed to sense the voltage across R7 caused by load current and reduce the output voltage so that the load current is the same as the setting of the current pot. U3 is the current reguator and its output reduces the voltage of the output stage through D9.
With the current pot at half rotation the output current should be regulated and limited to only about 1.7A.
Your voltage from pin 6 of U2 does not go high enough up to about 34V so the project's output cannot go up to 30V. Is your transformer only 24VAC?
rufinus
Sep 4, 2006
19
Hi audioguru. Thank you very much for your reply.
Fuse is inserted straight after secondary winding before rectifier in order to protect the winding. It had a value of 2.5 amps and before everything was working excellent.
I do have a 24v transformer and for building this psu i used your 24v mod parts list.
So, do you suggest that D9 or U3 is dead?
audioguru2
Apr 6, 2004
12,022
Hi Rufinus,
The current regulator has a max current output of about 3.4V if the value of the pot is a little high. You should increase the value of R18 to reduce the max output current to match the value of your fuse.
Test the current regulator by turning down the current pot to about half, turning down the voltage pot completely, adding a load to the project then measuring the output voltage. As the voltage pot's setting is increased then a voltage will be reached where the current regulator will stop the output voltage from rising and the LED will light.
rufinus
Sep 4, 2006
19
With the load of 1 ohm voltage stays at 0, it can not be regulated. Current pot is in the middle. LED is off.
With the load of 680 ohm voltage can be increased to 17.6v and then stops, but LED is still off. Current pot is in the middle.
LED goes on only when current pot is completely down.
Both loads are cold. It looks as there is no current basically  ???
rufinus
Sep 4, 2006
19
Here are the voltages measured at U3 with the current pot half way, load on (680ohm):
pins:
1 - -5.6
2 - 0v
3 - 1.48v (can be regulated with the current pot 0-3v)
4 - -5.6v
5  - -5.6v
6 - 31v
7 - 31,8v
audioguru2
Apr 6, 2004
12,022
A 680 ohm load causes only 37mA if the output voltage is 25V. The current pot would need to be turned up to less than only 1% of its rotation for the circuit to begin regulating the cuurent.
Use a much lower value for a test load resistor to make enough current for you to see if the current regulator works.
rufinus
Sep 4, 2006
19
Voltage pot does not change anything. Current pot also does not change anything.
There is no current regulation. Ammeter in the series with the load (1ohm) shows 0.03amps independent of current or voltage pot adjustment.
Load resistor stays cold.
audioguru2
Apr 6, 2004
12,022
Hi Rufinus,
The LED is off so U3 is not reducing the output voltage, something else is.
Maybe Q2 is destroyed by the very high current you had when the fuse blew.
1 ohm is much too low for testing. If the output voltage is 25V then it would try to draw 25A!
Try 12 ohms to 20 ohms. If the current regulator doesn't work then the max current will be about only 2A.
rufinus
Sep 4, 2006
19
Tried with 20 ohm. I did set voltage pot to 25v and current pot to half-way. When i connect the load, voltage drops to 0.6v and current is about 0.03-0.04 amps.
Current and voltage regulation pots do nothing then.
audioguru2
Apr 6, 2004
12,022
Hi Rufinus,
With the 20 ohms load connected, the voltage pot set to 25V and the current pot to half-way:
1) Measure the output voltage (pin 6) of U3. It should be high which is about +31.8V in your circuit.
2) Measure the input voltage (pin 3) of U2. It should be about +8.1V.
3) Measure the output voltage of U2. It should be about +26.4V or higher.
4) Measure the base voltages of the output transistors. They should be about +25.5V or higher.
rufinus
Sep 4, 2006
19
pin6 U3  31v
pin3 U2  8v
pin6 U2 3v
base q4 0.5v
base q2 0.7v
all measurements with the load of 20 ohm
without load, pin6 u2 is 25v
eggy1
Dec 4, 2006
14
Got mine working. Voltage is 0-30,0V. One problem remained...R2 is heating....quite fast, after few minutes I can also smell the resistor besides seeing it.
audioguru2
Apr 6, 2004
12,022
Hi Rufinus,
Your Q2 and Q4 transistors are not working. Maybe D10 is shorted or it is connected backwards.
rufinus
Sep 4, 2006
19
D10 was shorted.
Many thanks goes to audioguru, the man, who cares.
Respect.
Now i wont connect ammeter between emitter of Q4 and output. I will better use voltmeter to measure across R7.
I did build one based on 7107 and it works fine (as a panel meter for this project). Now i have one more, also based on 7107, configured for 200mV full range and with a voltage divider at the input to have full scale of 20.00v. I guess, i can use it as ammeter if i measure voltage drop across R7?
Another issue is grounding. Here in Germany we have a grounding pins on the plugs. Should i connect the common of the psu to the ground, or just leave it floating and ground only the enclosure?
audioguru2
Apr 6, 2004
12,022
Hi Rufinus,
Good, you fixed it. ;D
Now you can measure its performance. The voltage regulation is much better if you do not connect a current meter to its output. Measuring the voltage across R7 is a very good way to measure the current used by a load.
All my test equipment are not grounded. They all have "approved" power transformers.
subodhthok
Mar 4, 2007
11
I building this circuit on a multi-purpose board. Kinda confused about RV1. The middle pin of RV1 is connected to R1. Other 2 pins to which pins of U2??? I think one is connected to pin 6 (o/p of U2) but the other????
