audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
The driver and output transistors are simple emitter-followers so their output voltage should be 1.2V to 2V less than the voltage at the output pin 6 of U2. Since your output voltage is much too low then either your transistors are connected backwards or they are blown up.my voltage out of u2 was always 17 volts now when i fixed the bad trace i can adjust up to 17 volts only. i get a max voltage of 34 volts between ground and positive rails i get a max at pin6 of u2 of 34 volts but only get 17 at output.
The collectors of the driver and output transistors are both connected to +34VDC. They are also connected to their metal case so they must be insulated with thermally-conductive insulators from the heatsink or the heatsink must be insulated from 0V.does a heatsnk on transisters have to be grounded?
