12 volt under voltage controller wiring
Alan Gill
Dec 2, 2019
I'm wondering if you could help me with a question about using a low voltage controller on a 12 volt car auxiliary circuit.
The set up I have is this:
 A 12 volt auxiliary battery that provides power for a 12 v fridge. The auxiliary battery is charged via the alternator and a solar panel.
 I want to put a low voltage controller into the circuit so that the battery does not get drained below 11 volts.
 I have purchased a control unit but I am concerned that the wiring for the fridge is too heavy for the small controller to wire it directly into the circuit.
 What I am wondering is can I wire the low voltage controller through a relay that would turn the power on and off to the fridge? I assume that I would need to put some sort of electrically controlled switch that the relay would activate.
HarryA1
Mar 4, 2009
481
