PWM on 12volt winch?
Maglatron
Jul 12, 2023
2,025
so I was thinking could I use PWM with a power relay that handled the amperage possible?
Maglatron
Jul 12, 2023
2,025
Personally I'd use a 100A device (with suitable thermal/overcurrent trip, resettable) and be careful how I used it. I'd also use a bypass switch to run it at full current when that was necessary - probably not very often.
Even a low current controller can be modified to work at MUCH higher currents by changing the switching device (probably a MOSFET) for one - probably a few wired in parallel - device rated for much higher current.
You can get N-channel MOSFETs rated at 30V and 500A (IRDS(on) value of 0.0007ohms!) for £1.20 at Farnell.
Use any good component supplier and their parametric search engines.
so could you elaborate on how to do this please?
Minder
Apr 24, 2015
3,561
You don't have the motor technology yet. do you?
Maglatron
Jul 12, 2023
2,025
Not yet, working on it. If I were to pay for someone's services I would pay for another winch and let whoever wants to take the job determine the motor type and figure out how to control it's speed and make a nice little control box and send me the winch with the modification of the added control box / panel. Easy money for those that know how! I have to mention, this speed controlled winch is a neccessity for me!
Maglatron
Jul 12, 2023
2,025
But yes still at the moment trying to get hold of my mate but I'm betting even if I do I wouldn't trust that he'd be able to help to be honest with you! like I say he's not too technical!
Maglatron
Jul 12, 2023
2,025
or perhaps you could point me to a winch that you already know the motor type, for me to buy, and the talk me through modifying a low current controller to handle the high current that the winch needs, maybe?
Alec_t
Jul 7, 2015
3,821
I want to gradually increase the speed of the winch, not just on or off, to take out the jerk,
Couldn't you simply pull the load via a strong coil spring to avoid the initial jerk?
Are you sure the winch doesn't already have a soft-start feature?
Maglatron
Jul 12, 2023
2,025
no not sure, I did think of the spring idea but for my needs, it isn't pheasible I am using the linear motion to convert to rotationals motion, I want to put a sprocket on to the shaft and turn a half ton flywheel via chain!! the inertia is obviously resistance to acceleration and I fear that the winch would snap the chain need gradual power onset and acceleration!
Alec_t
Jul 7, 2015
3,821
More likely the winch motor would stall or cut out, if the chain has been properly specified. With half a ton of flywheel attached the inertial load could keep the motor nearly stalled for quite a while.
I might just use a centrifugal clutch in fact
Per the posted spec, the winch already has a manual clutch.
Maglatron
Jul 12, 2023
2,025
Yes, but the centrifugal clutch wont stop the motor from turning and will give the flywheel chance to catch up to speed so that it runs in unison with the winch burning clutch is better than burning winch!!!
Maglatron
Jul 12, 2023
2,025
this is the reason I need to gently introduce the power
Maglatron
Jul 12, 2023
2,025
that's definatly a possibility never seen one before, what is the highest gear ratio you have come across because I still need the high torque, thanks
Maglatron
Jul 12, 2023
2,025
ok that is probably the most usefull thing that I have heard about yet, thanks man
Minder
Apr 24, 2015
3,561
If looking at mains options for the 2HP winch you have spec'd in, there is also the readily available TreadMill motors that go up to 2Hp - 3 HP.
The example of one of the popular MC2100 controller that uses PWM and slow ramp up, desirable in a TM.
The one thing to add for this option is a reversing relay.
Minder
Apr 24, 2015
3,561
That is a fraction of the motor power to the original one mentioned?!
Maglatron
Jul 12, 2023
2,025
hmm ok I'm open to suggestion I take on board what you said about the tread mill motor will look into that, just looking for a heavy duty speed controllable motor let me know!
