PWM on 12volt winch?
Maglatron
Jul 12, 2023
2,025
I want to know if you can control the speed of a winch that normally turns at one speed? thanks
danadak
Feb 19, 2021
1,096
What is type of motor on the winch ? PM, series wound, shunt......
Regards, Dana.
Minder
Apr 24, 2015
3,560
So 12v it will be DC, but it could be brushed motor or BLDC, either can possibly be controlled using PWM.
But you will lose some power with the PWM reduction so it all depends on load.
kellys_eye
Jun 25, 2010
6,512
Lots of 12V PWM controllers on Ebay. If yours is a 'brushed' motor then there's loads of solutions.
Maglatron
Jul 12, 2023
2,025
ok before you RTFM on me, I'm on it
so nowhere in the manual or extra information does it mention brushless or brushed no mention of brush, is there any other way to determine what type of motor is inside? thanks!
Minder
Apr 24, 2015
3,560
I suspect it may be 3ph brushless (BLDC) as used now on motorized bikes etc.
If the rear end is vented, you may be able to spot if it does indeed have brushes or not..
Alec_t
Jul 7, 2015
3,818
Theoretical current draw at the rated output is 114A. Peak (start-up/stalled) current will be greater, probably a good bit greater. You'll need a hefty PWM controller! Also a good battery.
Maglatron
Jul 12, 2023
2,025
ok the motor part is a sealed unit, I would take it to pieces but going to call up machine-mart on monday and ask which sort of motor is inside the winch thanks guys!
Maglatron
Jul 12, 2023
2,025
Any suggestions on a PMW controller that would suit, I would preferably like one that could handle 30% extra than what is needed, cheers
To begin with, you have not yet determined what type of motor it is.
If it is 3 phase brushless, you won't do it with PWM.
If it is a brushed type motor, you certainly will not find a pwm device on Ebay capable of those currents, at least not of any ,what would be considered, quality.
If you do find any off-the-shelf pwm controller capable, be prepared to pay many times more than the cost of the motor.
As my grandfather used to say, if you want a Ferrari , buy a Ferrari.
Maglatron
Jul 12, 2023
2,025
ok I'll get the motor type first of all
@Maglatron
Please supply the community with a minute by minute update.
Much appreciated.
joking or serious?
Maglatron
Jul 12, 2023
2,025
So this leads to the next question if it does turn out to be brushed type how would I go about making a PWM controller capable of handling those currents? thanks, and IF it's a 3 phase how would I make a speed controller for that!!??
Martaine2005
May 12, 2015
5,308
That’s not an update.
That’s more questions before you’ve answered the first!.
Keep on track and find out what motor you have first.
Maglatron
Jul 12, 2023
2,025
ok so the machinemart shop is open till 4 O'clock today, I will call them when the phone is free and ask the people the type of motor in the
Ninja 3500 Electric Winch - Steel Rope (12V)​
and should have an update soon with the type of motor inside the winch!
feel free to call them first 0115 956 5555
Maglatron
Jul 12, 2023
2,025
so I called the number and I have to call back tomorrow between 8am and 6pm for the technical team, they will provide answers so have to sit tight for a day!! number for technical team tel: 0871 410 1260:)
