12V to 72V invertor for battery charging
N
N_Cook
Scenario 12V,20A wind generator to charge a bank of 6x 12V batteries to run
a 72V motor.
What would happen if you ran a 12V to 110V sine or quasi-sine invertor ,
through a high power rectifier to the bank of 72V batteries ?
What other considerations , protections etc , should it work ?
Paul E. Schoen
run
a 72V motor.
You should be able to build six isolated DC-DC converters with a wide input
range to accommodate the voltage variations of the generator, and also
individually provide the optimum charge for each battery. Such a charger
(about 25 watts) can be made using a PIC or one of many battery charger
ICs, and you could add a visual "state of charge" LED indicator to each
battery to detect problems.
Paul
MooseFET
No, the PIC is the wrong part for this. You want an LM555 :>
A two LED or two color LED indicator is a better way to go. You have
more than two states to indicate:
Blink green I don't see a battery
Green The battery is fully charged
Blink yellow The battery is very low
Yellow The battery is being charged
RED Big trouble I've stopped charging this battery
gearhead
a 72V motor.
What batteries, what wind turbine?
Same goes for the inverter.
Paul E. Schoen
What's wrong with a PIC? They now have the PIC12HV615 and the PIC16HV616
that have built-in voltage regulator, 4 channel PWM, comparator with S-R,
600 mV reference, and other goodies that are specifically for switchmode
power supplies and motor control. You can sense battery voltage and current
for both charging and discharge, and directly drive LEDs as you suggest. I
would use a slightly different color scheme, and use a low repetition blink
to indicate status when not under charge (to conserve energy).
The difficult part is the isolation. But you can make a very simple DC-DC
converter on the 12 VDC generator side, to produce an unregulated raw 12-20
VDC nominal supply on the battery side. Then it is easy to make an
efficient current regulated, voltage limited charging supply similar to the
PWM LED drivers that are being designed and built by many companies (Zetex,
Linear, TI, etc.). The PIC can be programmed for various cell chemistries
and charging profiles, and also compensate for temperature.
I have also seen a PIC circuit for Lithium cells that can be chained to
others in a series battery pack, and it will communicate with the others to
provide an optimal charge for all, and shut down if there is danger of
current reversal.
Paul
MooseFET
Real men use LM555s. :)
You hook a zener to pin 5 of the LM555 :)
This is a wasteful way to go. It is better to send the information
about the charge state back to the input side and only have one DC-DC.
Since you like the PIC so much. Put one on the load side to encode
the information for sending back digitally.
