2 latching relays, 2 pushbuttons, 2 dc 5 Volt motors and 4 limit switches
Holz1
Jul 19, 2022
33
Hello FORUM,
On the forum I have seen a lot of posts with respect of dc motors and limit switches operated by SPST and DPDT relays but not for operation with latching relays which I am using.
I am not a skilled electronic technician but a hobbyist.
Enclosed you will find a circuit diagram for the running and stopping of 2 5 volt dc motors controlled by /with 2 HONGFA latching relays.
Explanation of circuit diagram
Activation of PB1 switches ON relay 1 and 2 and both the 5 volt DC motors are running CW until the GREEN activators are reached. The motors are deactivated.
Activation of PB 2 the relay 1 and 2 are switched ON and the motors start running CCW until the RED activators are reached. The motors are stopped.
Problem:
It does not work. I have made the circuit with only 1 latching relay and it works/operates.
I think the problem are the diodes and the way they should be placed. And here stops my knowledge and I have tried several positions but I cannot find the solution.
Can somebody help me with the correct circuit
Thanx in advance
Harry
CircutScoper
Mar 29, 2022
300
Hello FORUM,
Problem:
Thanx in advance
Harry
Hi, Harry. Question: Your schematic suggests that your "actuator" limit switches are normally closed, and open (breaking the circuit) when your motors arrive at the limit of their motion cycle. Is this true, or are they normally open and close at motion limit?
If the former is true, then I don't understand how they can control latching relays.
Minder
Apr 24, 2015
3,560
I didn't study the circuit in detail, but it is common to use NC L.S with a diode rectifier across the switch, When the actuator reaches its limit, the switch opens and disconnects the motor, but the L.S. diode polarity "arms" it for the opposite direction.
Unusual to use latching relays to begin with as any fault requires activation of certain sections of the control circuit to shut the motor down rather than fail safe where things just stop with control circuit deactivated.
Limit switches as a result of the above, instead of being in the control circuit where they belong, end up in the motor power supply, bad design.
Suggestion for future would be get one unit working first before adding complications and possible errors with two systems.
CircutScoper
Mar 29, 2022
300
Why not just one relay?
Hello FORUM,
Problem:
Thanx in advance
Harry
No worries...thought they were standard relays..... nothing marked so who would know.
Limits are still in the motor power lines and no way to stop except manually press limit.
Soon as released it would run again.
Still an upshot design......
CircutScoper
Mar 29, 2022
300
Soon as released it would run again...
Que anon. When a limit switch is pushed open, the corresponding motor stops, holding the limit open and the motor stopped.
CircutScoper
Mar 29, 2022
300
You can do it with a standard relay.
Holz1
Jul 19, 2022
33
Good morning.
Every circuit has a variety of approaches of problems. I like to solve the problem how to connect the 2 pushbuttons with 2 latching relays activated at the same moment. pushbutton 1 will activate 2 relays and pushbutton 2 will switch back the 2 relays. This is not working in my tests.
The actuators are pushing down the leafswitches which are NC and the motors are stopped.
Because the 2 motors have not the same speed, I cannot use 1 relay in my situation. Each motor has to be controlled by 1 relay . So 2 relays will activated at the same time by 1 pushbutton as described in the diagram.
I use latching relays because they hold their position until the next PB is activated.
Holz1
Jul 19, 2022
33
Is it possible to draw the above circuit but then with the 2 latching relays and 2 pushbuttons Normalle Open (NO).?
PS. I tried my circuit with 2 PB and 2 relays without the motors but only with leds. This is working, but when I connect the motors with leafswitch it does not operate as I expected. The problem are the diodes and to place these in the circuit.
CircutScoper
Mar 29, 2022
300
If you want to unnecessarily waste a relay, go for it.
CircutScoper
Mar 29, 2022
300
Oh, okay. Maybe you live in a land where latching relays are cheaper than diodes.
Holz1
Jul 19, 2022
33
Now, I am intrigued! You mean there is a solution to switch with only DIODES and ZERO relays? What are the white rectangles near the diodes indicated by the S (set) and R (reset)? Resistors?
Holz1
Jul 19, 2022
33
Looking at the new diagram, I see you switch the 1st relay with diodes through + 5 Volts and leaving the fly-back diodes for 2nd relay. Can you explain to me in simple words why?
CircutScoper
Mar 29, 2022
300
Because both pairs of relay coils are connected in parallel, one pair of diodes serves both.
CircutScoper
Mar 29, 2022
300
The rectangles represent the relay coils, just as rectangles do in your diagram.
CircutScoper
Mar 29, 2022
300
Hereabouts you can buy ~100 1Amp diodes for the price of 1 dual-coil latching relay. Therefore saving 1 relay at the cost of adding 4 diodes, as my design does, is something anyone with aspirations to become (or act like) an engineer should be interested in.
Holz1
Jul 19, 2022
33
Thnak you very much. I will try it to day and I will disconnect the pair of diodes from the second relay as you suggest.
I keep you posted.
Holz1
Jul 19, 2022
33
Now I understand this drawing in conjunction with the drawings containing 2 relays. I will 1st build this one.
Thanx!
