28 Pin eeprom chip switch
pietercc
Mar 19, 2024
New here, not sure if this is the right category for this, I am looking for something to make it easier to swap in between two 28pin memory chips, as in have the 2 pugged in, and just have a toggle between the two. The chips I am looking to swap between are both 27sf512, Not sure what else to say, just curious if someone can point me in the right direction.
Martaine2005
May 12, 2015
5,318
Hi, you may be able to simply stack them and ONLY switch the VCC.
Or if on perfboard, use sockets for the ICs and only switch the power input (VCC)?
Martin
14,317
I beg to disagree.
That'll leave the unpowered switch with logic signals at the inputs. Undefined behavior will be the case.
Better to switch the [imath]\overline{CS}[/imath] signal like so:
This is how it's meant to be connected. The inactive Chip will drive its outputs to a high-Z state and thus will not disturb the output signal from the active chip.
pietercc
Mar 19, 2024
I beg to disagree.
Sorry I am getting back on this so late, the data sheet doesn't seem to have a CS pin, though I do see a CE, would that work to switch it?
14,317
CE = Chip Enable
CS = Chip Select
These are essentially the same.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
There is also an active-low OE = Output Enable pin that you must use if paralleling the outputs (recommended).
_
