3.2v LEDs 12v battery
Martaine2005
May 12, 2015
5,318
You can get lots of good components from broken and thrown out electronics equipment.
Arouse1973
Adam
Dec 18, 2013
5,178
Aren't they usually so well soldered that I would end up damaging them
Just use your soldering iron and a pair of tweezers or a small set of long nose pliers. Heat one end and pull carefully out of the solder joint. Do the same for the other side. You don't need the iron on them for long, just enough to melt the solder.
Adam
Martaine2005
May 12, 2015
5,318
No not at all.
SMD components might get damaged if you take a long time.
But generally, you only need a second with a soldering iron.
Most people who have problems de-soldering and damaging components don't know how.
I normally put a little fresh solder to the joints and then it's easy..
Orion96
Dec 18, 2015
26
No not at all.
Thanks I'll try with some useless parts, I've never been good with soldering
Tha fios agaibh
Aug 11, 2014
2,253
If the Leds are rated at 20ma and a fully charged battery has around 12.7v, that would put you over at 26ma if you uses the R120 resistors.
