in many circuits there is an air coil, they told you that it is say 0.1 uH and also told you number of turns you must made and the former diameter and if this close wound or loose. If i try different values to achieve the same 0.1 uH using some formula, is then this coil operate ok as the previous mentioned.
Thanks.
Thanks.
