K
Kasamiko
- Jan 1, 1970
- 0
That 370 VDC will be tapped directly to TV's main filter capacitor, 220uF/450VDC..then goes on TV regulator for 115VDC output for the rest of the circuit.. ;D
rhonn
rhonn
You could increase the efficenciey by bypassing the TV's internal regulator, modifying your circuit to give 115VDC and using it instead of the internal regulator. Doing this you could save quite a few watts.Kasamiko said:That 370 VDC will be tapped directly to TV's main filter capacitor, 220uF/450VDC..then goes on TV regulator for 115VDC output for the rest of the circuit.. ;D
rhonn![]()
So you wan to be still be able to run this TV of the mains as well as a battery.Kasamiko said:It's a good idea but then it will render the AC/DC function of the tv useless..![]()
Hi Sasi,Sasi said:And this is the smallest inverter I have ever made....120VA used by my brother in his CAR.
The calculation for the frequency of a CD4047 oscillator is shown in its datasheet. It is used as a 50Hz or 60Hz oscillator in our 500W inverter project and here is the corrected schematic of its oscillator.kachew said:can pls teach me how to calculate for the CD4047 and the MM5389 to get 50hz output??
Nope. They are still in business many years later and so is my computer's manufacturer.Ante said:Your hose supplier will eventually go bankrupt, that's a stupid way to operate a business.
