Dear Audioguru, please can you lell me where can I find a full text about your FM Tx whose circuit is attached below.
thank you.
thank you.
An electret mic works well when operating at its spec'd 0.5mA. Half the supply voltage across the mic determines the resistor's value.walid said:1) How u made the mic preamp sensitive enough to pickup sounds in a room. I guess through R1, the resistor feeding Vcc to the MIC.
You said once a day that the rule u use when choosing this R1 is that when Vcc = 9V, R1 = 9K, and When Vcc = 3V, R1 = 3K and so on.
Try both. The 4.7k might be slightly better. You might not notice the difference, it will be very small. ;Dwalid said:So if I want to build this Tx using a mic from a radio/cassette, then i must put R1 = 4.7K and not 10K, or whay you say?
