Hi guru
I know that this circuit is not better than yours, but I have a chance with this.
when I build a circuit and didn't work it is more easy to me to build anthother new one than searching for the problem in the first, it is very complex and make headache. it is hard to me, after 4 hours of work and organize, to look again for the causes, especially if i use a used parts from my junk, the possibility is large.
thank u guru
yes exactly, i noticed this. I'll redesign it after your help, and with u makeing its range more.That circuit is nearly the same as mine, except its frequency will drift as the battery voltage runs down because it doesn't have my voltage regulator.
please explain this statement.It also won't boost treble audio frequencies which are cut in FM radios.
If I increase RB or decrease Rc, then I'll have more voltage gain!The easiest way to increase its range is to use a 9V battery instead of only 3V. But then the 1st transistor will probably saturate and will need its base resistor's value increased or its collector resistor's value decreased.
u mean "motorboat" after using 9 v battThe microphone's powering resistor is connected directly to the battery and the supply bypass capacitor has a low value which is good for RF, so the circuit might "motorboat" until you add a 100uF supply bypass capacitor.
also your FM Tx has no -ve FBThe output transistor is connected without any negative feedback to control its operating point.
I need more explaination to this point.Transistors have a wide range of current gain so some have low gain and will be cutoff in this circuit and others will have high gain and the transistor will be saturated.
to make the last stage a collector feedback configuration, but doind this adds what to the circuit.The simplest fix is to change the value of the 150k resistor to 68k then connect it to the collector instead of to the supply.
thank u guru
