audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Hi Walid,
You should never assume Vbe in a transistor circuit that has a low emitter voltage. It is typically 0.62V on my datasheet.
I used the parts I had. I didn't have 320k for R2 nor 60k for R3 so the divider current to base current ratio is 20:1 instead of 10:1 which better controls the effect of different current gain in different transistors.
My Mod-3 version of the circuit had an extra emitter resistor to raise the emitter voltage so that different Vbe in different transistors wouldn't affect the collector voltage too much. But I didn't have space for it and a large bypass capacitor for it.
The pre-emphasis at 15kHz in North America is about 7.2 times the gain at lower frequencies. With its lower frequencies gain of about 18 then the max gain of the transistor of about 130 results in a pre-emphasis which just makes it and sounds perfect.
You have used hFE (DC gain) of 230 in your calculation for Zin instead of Hfe (AC gain) of 100 so the actual impedance is less. Since the pre-emphasis capacitor affects only high frequencies then the correct value for input impedance occurs only at about 30kHz and higher. At lower frequencies the input impedance is much higher. ;D
