oldgrandpainmi
- May 14, 2006
- 62
- Joined
- May 14, 2006
- Messages
- 62
Hello all.
I understand the difference between a standard lead/acid automotive battery versis a deep cell lead/acid battery. What I would like to know is the actual difference between the corresponding chargers.
I run deep cells while fishing, and am aware that using a standard charger will not work correctly and you shouldn't charge a deep cell on an automobile (jumper cables).
Is there a circuit available for a typical 2/15/100 automatic charger? (2a slow charge, 15a fast charge, 100a start) Building one is out of the question, as it is much cheaper to buy than build, so the circuit would be for my reference.
I also would like to know if there are any problems trying to charge 3 or 4 deep cells on a charger at once? (parrellel hook-up)
Lasty, is there a way to rejuvinate lead/acid battery's, much like rejuvinating NiCad's?? (NiCad Zapper)
Any ideas?
oldgrandpainmi
Any ideas?
oldgrandpainmi
