About that LCD...sorry for being persistant :
Why would it jump around? What is it made for if it jumps all over on a DC? One person who rated it said he use it on a battery and it just jumped in the tenths (in other words what is the difference between the supply and a battery as long as your not turning the pot all over).
Also I will have no problem powering it. I (already) have some lighted toggle switches that I want to use..I'm including outlets on each side of the box that can be turned on and off for things like glue/solder gun so there is no unplug--re-plug. So I can light the switches and the meter with a 9V battery and turn the whole system on and off with a DPST (<no problem with the meter saying on Staigen
Also check out my question about the capacitors in the previous message. That's where I'm still confused.
I should've know with that meter...the volts will be even between the meter and the outputs no matter what...I was thinking with the rules of amps for some reason. By the way: Do I actually need a shunt (if so what kind)?
Do you always have to have a capacitor to use a 555? (I know, A very off subject question but I have some 555s and a breadboard now but I dont have capacitors handy. Do you suggest I get one of those packs of 50 (for example) different capacitors and one for resistors to be able to expiriment with different values for projects?
I was thinking...(as I usually do alot of)..Those chassis mount trans. Do AC to AC the u have to have the bridge and the cap. I can't think of when I'll need anything above 12V so wouldn't it just be easier to ad a 13.5V 1A AC to DC wall trans. and can skip some of the problems. (^The 24V ones don't go up to 1A^)
>>If I can do this, what all do I eliminate/change?
Would the LCD not flicker then? ;D
