An entire schematic with parts would fill several pages.
The basics of a UPS are just a two units.
- a charger to keep the batteries topped off.
- a Inverter to change the power from DC to AC.
The charger isn't to complex.
The Inverter is the tricky part.
All an inverter does is create a sine wave (usually 50/60hz)
then feed that sine wave into a very high power amplifier.
If you want 120V AC at 60Hz then build a push/pull (Half bridge)
amplifier that can supply the needed current (or wattage)
The trick is to drive the amp with only the battery power.
A hint, Most UPS systems use 48V batteries (Four 12V's in series)
If you swing that through a transformer forward then negative you can
get 48Vpp or 73Vac.
If your transformer can handle bumping that up 3:5 ratio then you have
120V.
If this still sounds like something you REALLY want to try then you will need
to define a few basics first. How much power do you need. How long does the UPS need to run, Is the UPS a pass-though or a fail over design, Will you be driving resistive or inductive loads, and why would you want to build a UPS in the first place?
Answer these and I'll help some more.
-Mike
