CA3096 transistor array?
Chris Carlen
Hi:
I have a bunch of Intersil CA3096AE left in my drawer in DIP packages.
I need the same thing in SOIC. I'd like to build an adaptive trigger
such as the one Linear Technology likes to put in many of their
comparator datasheets:
LT1394:
http://www.linear.com/pc/downloadDocument.do?navId=H0,C1,C1154,C1004,C1012,P1664,D3867
Does one need matched transistors for this, or is their choice of the
CA3096 just a convenience of packaging, and I could get away with two
each of 2n3094/2n3096 ?
Thanks for input.
Good day!
________________________________________
Christopher R. Carlen
Principal Laser&Electronics Technologist
Sandia National Laboratories CA USA
[email protected]
NOTE, delete texts: "RemoveThis" and
"BOGUS" from email address to reply.
Chris Carlen
Chris said:
Hi:
I have a bunch of Intersil CA3096AE left in my drawer in DIP packages. I
Forgot to mention that this part is discontinued.
Good day!
[email protected]
Tim Wescott
Chris said:
Hi:
need the same thing in SOIC. I'd like to build an adaptive trigger such
as the one Linear Technology likes to put in many of their comparator
datasheets:
LT1394:
Thanks for input.
I suspect you could use diodes for Q1 and Q3, and any old NPN and PNP
for Q2 and Q4 -- but Zetex makes matched pairs, which Digi-Key sells.
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Posting from Google? See http://cfaj.freeshell.org/google/
"Applied Control Theory for Embedded Systems" came out in April.
See details at http://www.wescottdesign.com/actfes/actfes.html
W
Winfield Hill
Tim Wescott wrote...
This circuit (figure 18), which is said to operate to 45MHz, looks
like it could well benefit from fast low-capacitance transistors
for the bipolar peak-follower function. Sadly Intersil no longer
offers the ca3096, but they do offer the hfa3096, which is a high-
speed RF-transistor array replacement, featuring three matched
8GHz NPNs and two matched 5.5GHz PNPs, in a 16-pin soic package,
available from DigiKey, at $3.18 each. While I do agree with Tim
that these transistors don't have to be well matched, it certainly
can't hurt, and will likely extend low-signal-voltage operation.
CC
Yeah, I saw those UUHF arrays.
So the point is, there is nothing *bad* about using the excessively fast
transistors?
I guess I was worried about the possibility that such transistors can
become oscillators in frequency ranges where I wouldn't even be able to
measure with my lowly 500MHz scope, yet the occurence could manifest as
peculiar and undesired behavior/malfunction.
Can one simply add a few pF of collector to base capacitance to make the
transistors effectively slower if such silliness is suspected?
I don't know if I really need that adaptive trigger.
I actually used a much slower version of it once before in a free space
optical transmission from an engine piston, where the brightness of the
data was varying with the piston location. It worked quite well.
I have a simpler application now, just position sensing of a wheel where
the sensors are in fixed positions. I can tune the gain and align the
optics to make it work just right. But something about things that have
to be tuned just right makes me feel unsatisfied.
Thanks for the input.
Good day!
W
Winfield Hill
CC wrote...
Yeah, I saw those UUHF arrays. So the point is, there is nothing
*bad* about using the excessively fast transistors?
Well, they're fragile, and subject to ESD damage during handling.
BTW, they give the spec for a maximum high current, the transistors
are slower at ordinary currents, for example 5.5 and 2GHz at 1mA.
to measure with my lowly 500MHz scope, yet the occurence could manifest
as peculiar and undesired behavior/malfunction.
the transistors effectively slower if such silliness is suspected?
Some added base-emitter capacitance, say 1.0pF, might be safer.
Or you could run them at 100uA (Jim had to bias the old ca3096
at 2mA to get 45MHz). A well-placed feritte bead usually works.
I stock and use the attractive Panasonic smd PNP and NPN pairs,
xn4401 and xn4501. These come in 6-lead 0.95mm sc-74 packages.
They contain separate 2sb709 or 2sd601 transistors (50V, 50mA,
80MHz and 150MHz, 3pF), which are not explicitly matched,
although they probably come from the same wafer.
Maybe these parts would be a better choice for your application.
Mike Monett
Winfield Hill said:
CC wrote...
manifest as peculiar and undesired behavior/malfunction.
Definitely would not do this, Win. Most parastic oscillators are running as
a Colpitts using stray capacity and interelectrode capacity as the divider,
and lead length in the base as the inductor.
The best bet is to minimize the length of wires connected to the device,
especially the base. Then always add a 10 to 47 ohm series resistor at the
base. This will kill bandwidth and risetime, but it's better than a
parasitic that may come and go with changes in supply voltage, temperature,
stray hand capacitive effects, etc.
JL recently mentioned having to add these resistors to a fabricated pcb.
This can be a pain, so put them in the initial design.
Regards,
Mike Monett
Jim Thompson
On 23 Jun 2006 04:39:17 -0700, Winfield Hill
[snip]
[snip]
Wasn't it the 3046 I used in that example?
The 3046 is on an absolutely ancient process with emitter sizes of 20u
X 30u.
...Jim Thompson
W
Winfield Hill
Jim Thompson wrote...
Winfield said:
(Jim had to bias the old ca3096 at 2mA to get 45MHz).
[snip]
Sorry, Jim, I as referring to Jim (Williams, that is).
His circuit required two each NPN and PNP transistors
which he specified as in a ca3096 array.
emitter sizes of 20u X 30u.
Yes. What about the ca3096, same story?
CC
Ok, thanks for the Panasonic part #s.
Jim Thompson
[snip]
I thought you were referring to my video amplifier example.
Likely.
...Jim Thompson
