autir said:
What I've understood is that:
-> We do not need polarised capacitors. We use electrolytic capacitors not because of the polarity they posess but because of their high capacitance values. Electrolytics in this case can be installed in either direction, their polarity is unimportant. The proper thing to do, regarding quality, is to use expensive film capacitors of the desired values.
No. Polarity is extremely important with polarized capacitors, that is why it is marked. If they are installed backwards they blowup like a bomb if the charging current is high enough! Carefully try it.
With a low charging current a backwards polarized capacitor leaks a lot of DC current and its capacitance decreases over time.
-> The only case we really need a polarised capacitor is when blocking DC or connecting stages whose voltages differ by far.
You never need a polarized capacitor. Polarized electrolytics are cheaper and have high values.
Why do electrolytic capacitors produce higher distortion than film ones? Is it a symptom of the polarisation of the electrolytic capacitor, or does it depend on the different nature of the two species?
They just do have higher distortion. Maybe it is because their capacitance value changes with DC voltage, resulting in 2nd harmonic distortion. Their value isn't accurate anyway.
Why do two polarised capacitors connected in series produce a non polarised capacitor? Does it matter whether the + or - ends are the ones connected?
Since they are in series then their combined value is half of each one.
One will have the correct polarity and therefore have very low DC leakage current and the "backwards" one won't have any DC voltage across it.
It doesn't matter whether their "-" leads or "+" leads are joined.
To construct a non polarised capacitor by connecting two electrolytics is exactly the same with buying a non polarised electrolytic?
Yes, but yours will have the total value half of each one.
Can't we block DC or voltage differences in general with a non polarised capacitor?
Of course.
Is polarisation really needed?
Never, it is just a cheaper, fairly small capacitor.
Just think how many fairly expensive 1uF non-polarized capacitors it would take to make a fairly cheap 10F polarized "super capacitor". Ten million of the things! ;D
What do you mean by that?
A single polarized capacitor could be used since its polarity in this circuit is known.
One polarity when the power is applied because the output DC voltage of the preceding stage comes up quickly.
The opposite polarity when the power is turned off because the output DC voltage of the preceding stage drops to ground quickly. ;D
