convert speaker output to microphone input
Status
Not open for further replies.
bigkim100
Apr 17, 2013
270
Need to convert speaker output to microphone input on a board. I dont need high quality sound...just something quick and dirty.
Thanks in advance
Pick up the signal well before the amp section, simple.
That naturally depends on just what the signal is though.
bigkim100
Apr 17, 2013
270
I also found a 2 resistor circuit that is also very simple. It takes me back to the 70s, making a cable from my radios earphone jack to my recorders Microphone input (no aux input on my Sears unit) to record my songs.
Thanks Bluejets!!
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Thanks in advance
Could you clarify what you want to do? At first, I thought you wanted to use a speaker as a microphone (as most intercom systems do), but perhaps you want to take the signal, connected to the speaker from an amplifier, and feed that signal to the microphone input on a board. That might require a reduction in signal amplitude to avoid overloading the microphone input, something you can accomplish with a simple potentiometer. Any resistance potentiometer from about one thousand ohms to ten thousand ohms should work to reduce the level of signal to an acceptable level for microphone (low level) input to the board. You might also want to insert a fixed-value resistance in series with the potentiometer, to limit the range of adjustment, to avoid overloading the microphone input.
OTOH, if you want to use a loudspeaker as a microphone... more information is needed.
Status
