Digital radar speedometer
ante1
Jan 24, 2004
4,136
Hi Ted,
Interesting circuit this one. I have tried to analyse it but couldn
Ted1
May 7, 2004
5
There shoud be someone out there who knows how the timebase are calculated . I urgently require these theory analysis for my project.
MP1
Dec 7, 2003
3,397
Just a quick look, but it looks like two sets of 7404 setup as oscillators. One is flashing the laser diode and the other is "anded" with the return signal, then this is processed and a calculation is made of the difference.
Not much, but hope it helps.
MP
ante1
Jan 24, 2004
4,136
MP,
Thanks for your input I see what you mean. Could this be an accurate instrument do you think?
Ante ::)
Ted1
May 7, 2004
5
Thanks for your input, do you know of the formula to calculate the frequency , when using two not gates.
MP1
Dec 7, 2003
3,397
ante,
Radar is a bit out of my area of knowledge, but it seems like any reflection of the laser would cause you to lose accuracy when the signal bounces back. From the description in the project, it will only be accurate if you are directly in front of the object and it is moving toward you.
Ted,
I found an application note on oscillators here:
http://www.fairchildsemi.com/an/AN/AN-118.pdf
Lots of info and the formula is also there. Hope it is helpful.
MP
Ted1
May 7, 2004
5
Thanks MP.
It was very helpful.
I can now move a step forward with my analysis.
Do you happen to have a good source of info on D flip flops . I want to use one as a start and stop gate.
MP1
Dec 7, 2003
3,397
  • flip_flops_and_momentaries.pdf
hazanohazizul
May 22, 2006
6
hai.... can someone help me, i was during the digital radar speedometer project but i don't know what kind of Laser Diode and Laser LED that been used, can someone give me a part number PLEASE..... :)
hazanohazizul
May 22, 2006
6
Hi....
Do you know what kind of Laser Diode and Laser LED that been used in this project....
Can you give me the part number please.....
audioguru2
Apr 6, 2004
12,022
The laser receiving diode is wired so that it is forward biased and is conducting all the time.
I don't see how it can give an output.
hazanohazizul
May 22, 2006
6
laser diode it is not for transmitted but it for receiving a spot of light or a FC frequency
audioguru2
Apr 6, 2004
12,022
There is no such thing as "a laser receiving diode". It is just an ordinary photodiode that is sensitive to visible light.
MNA
Apr 9, 2006
204
Then Audioguru, how can the crkt work..... Is there any way to make it work?
audioguru2
Apr 6, 2004
12,022
I don't think that the circuit works with its photodiode backwards and without an amplifier.
MNA
Apr 9, 2006
204
So, can't it be corrected easily.....
can 74LS be used instead of 74AS ?
