audioguru said:
I simulated my FM transmitter and increased the value of its oscillator's feedback capacitor. It produces 11V p-p across a 75 ohms load which is 202mW RMS.
The collector current has a peak of 95mA. The transistor's collector current drops to zero on each cycle. As I suspected it operates in class-C.
The base has positive and negative 20mA peaks.
So the Hfe is 95/20= 4.75.
http://www.electronics-lab.com/forum/index.php?action=dlattach;topic=10866.0;attach=9361;image
Hi AG,
Are you sure about this? Using a non-linear simulator with vendor non-linear models for the transistor and coils (Q value 200), shows that the collector current never gets to zero, and the Vp-p on the collector is 3.4V giving only about 10mW F1 into the 75 Ohm load. AC load line analysis shows that it always operates in class A. Collector current swings between 16-41mA on the final transistor collector. This is your original circuit with fb cap 4.7pF.
With 10pF fb the output is under 30mW still operating class A. Vp-p on collector increase to about 6V.
Increasing the base resistor to 100k shows that the collector current starts to go below 0, but the power drops off to 20mW.
Have you actually measured these voltages on a scope?
