Function of an electronic circuit
johnbaker
Jan 31, 2021
Hello, I need to understand the exact working of an electronic circuit (see picture) but I am very bad at electronic. This is the electronic circuit of a personal alarm that triggers an alarm when you pull out a metal part (like a grenade). All I know is that when you remove the metal part (that looks like a piston) from , the metal disk on the left (which is a piezoelectric disc) produces a loud sound. I would like to know what exactly happens. What is the part that transform the electricity from the battery to an "alternative" current that makes the piezoelectric vibrate ? Thanks a lot to anyone that could help me
14,311
Likely the chip labeled U! next to the plug mechanism. You need to supply a better photograph to identify the chip. Or read the labeling on top of the chip and post it here. Could be something as simple as a 555 timer chip.
The assorted chips at the top are probably for driving the LEDs and for charging via USB.
johnbaker
Jan 31, 2021
Thank you very much for your help. I attached a picture of the chip but nothing is written on it. After having checked on the internet, i think it is a 555 timer chip but there should be something writtencylinder.jpg chip.jpg chip (2).jpg on it... And do you know what is the use of the black cylinder at the left of the plug ? I attached a clearer photo of it too.
Thanks a lot
14,311
Not uncommon for manufacturers to erase or paint over the labeling to "protect a trade secret".
The black cylinder looks like an inductor. As to its function in the circuit: no clear idea. It seems to be in the circuit that drives the piezo. It could be parallel to the piezo to create a resonant circuit. By using resonance the amplitude and thus the volume of the alarm would be increased.
