C13 is good. I made a conuctivity test betwen + and -. It conducts for 1 second, then capacitor is unconductable for few seconds.
Yes, it might work now, as I said earlier, that doesn't mean its life hasn't been shortened.
I think, that Q5 is ok, becouse it conducts between collector and emmitor.
That means its broken, it shouldn't conduct between the collector and emitter without a base signal.
Did you try to test the transistor whilst it's still in the circuit by any chance?
It also show resistance between Base and Emitor of about 600 Ohms and in other direction is about 2kOhms.
it shouldn't conduct in the reverse direction, unless your test voltage is higher than 5V which is too high and might damage the transistor.
Is That ok? I haven't check other transistors yet..
From the results given above, it looks like you've tested the transistors whilst there still in the circuit..
To do any meaningful testing, the transistor must be removed from the circuit before it's tested, otherwise other components in the circuit can influence the result: for example a resistor connected in between the base and collector can turn the transistor on.
I think you need to read up a bit more on transistors before continuing.
