As Q5 and Q6 carry a considerable current, the PCB traces need to be thick enough to carry the current, otherwise it'll behave like a fuse.Just to report, I made an LC filter to reduce oscilating and brum..I connected it in series with C13 and to power amplifier...It works great, but I burned everything ;D I turned Volume potentiometer to full and played for 2 minutes really hard, when suddenly everything shuted. I checked PCB and saw broken connection between Q6 Collector and ground..(it was verry tinny connection).
Of course the transistors need to be on a good heat sink..I repair it and replace C6. When I turned circuit on, it started to smoke..As I assume, Q4, Q5 and Q6 are dead. One of them was dead before (Q4 or Q5), so it started to smoke...I am wondering, if I am using to small cooling rib or not too good contact from collectors to cooling rib. I am waiting for new parts. I will replace every transistor and check them all to prevent puting in a faulty component. I will report and I just wanted to say, that LC filter solve the problem of oscilating in huge rating..I will report
If the amplifier is driving a 4Ω load, the heatsink should be rated to at least 4
