Looks good up until Q5 and Q6.Ok, I messured voltages somehow...:
VBE of Q4 (voltage accross R10) was 0.6V
VBE of Q3 was 0.6V
VBE of Q5 was 0.3V
VBE of Q6 was 0.2V
That sounds right to me.Author said, that I must check also voltage across Collector of Q5 and negative ground and across Emitter of Q5 and negative ground. Both voltages should be half of voltage supply. However, voltage across Collector and negative ground was 34V, and across Emitter and negative ground was 15V. Can that explain my problem? What should I do?
Did you manage to stop it oscillating?
If not then it's pointless trying to measure DC voltages because the AC could interfere with your meter causing it to generate inaccurate readings.
Look at the schematic, rather than just assuming what you've been told is true.
The voltage between Q5's collector and 0V should be equal to the DC supply voltage.
The voltage between Q5's emitter and 0V should be approximately equal to half the supply voltage.
I simulated it with a DC voltage of 30V and the voltage on Q5's emitter is 13.6V which is within 10% of the estimated value.
I don't know what is wrong with your circuit, your VBE measurements of Q5 and Q6 suggest that they should both be off, yet the high quiescent current indicates they're both conducting too much and the emitter voltage of Q5 also suggests they're both conducting.
