Hall sensor time out calculation
electronicsLearner77
Jul 2, 2015
306
I want to measure the speed using the hall sensor, one part of it is to detect hall sensor time out. I want to set around 150ms as hall timeout, that is there is no hall transition for 150ms. So, i wanted to confirm 150ms corresponds to 1000/150Hz = 6.6 Hz? Am i correct or any other factor to be considered? Please advise.
14,317
What do you mean by "hall sensor timeout"?
If you want to detect when there has been no transistion from the hall sensor's output within a timespan of 150 ms, a suitably set monoflop (monostable multivibrator) can be used. Here's an example.
No need to convert to frequency.
If a signal repeats at 150 ms intervals, that's equivalent to 6.66666 Hz (6.7 Hz after rounding). If the sensor's output changes more often, the frequency is higher.
Jul 2, 2015
306
Hall time out is no hall signal from Hall sensor connected to the motor. So, I want to consider if there is no signal (low or high) for 150ms then hall is disconnected.
bertus
3,882
Do you have a document to share where this signal is given?
Bertus
