Hello electronics brains!
My freezer is broken, tracked fault down to the fan which is not spinning. A replacement fan and motor assembly is going to cost me £95, and it looks like its just a 50p component that has blown on the control board.
My electronics knowledge is pretty basic, but it looks like a fat resistor, or possibly a capacitor. It looks to be coated in resin, and contains layers, but there are no markings, and the casing has cracked open. It has blown, and also damaged the tracks on the board. You can see the offending item sticking out on the photos I have included.
The component was connected to one of the terminals on the 230V AC input to the board, as the tracks have gone I cannot tell if it was sitting in series with the input, or across it.
In testing, I have connected it back up, (in line with the 230v in), and the motor runs for a few minutes before the component gets hot and my soldering falls apart. This makes me think it's totally ruined, or assuming its a cap, maybe should be wired in parallel to the incoming 230v.
Can anyone identify this? I am assuming is must be a fairly standard / common component.
If it's a capacitor, am I right in thinking this should be wired in parallel, ie both sides of the capacitor connected to the same incoming 230v live?
Or is it a resistor, to be wired in line with the input?
In my pics you can see the tracks which have lifted. The black circle on the 3rd pic is where the other side of the component used to be seated.
If anyone can point me in the right direction I would be most grateful. Would rather spend a few quid on a new one of these things that a whole new motor!!.
Thanks again
Ross
Thanks again
Ross
