Help needed with metronome using 555
ben9
Dec 30, 2005
Hi, I'm from Colombia, actually, I'm a musician.
I built a metronome using a 555 timer, and I'am very satisfied with the results. It works with a 12V DC supply, and works very well with batteries. The frequency of each beat is perfect, even when I use lower voltages. (I have tested it with 3.0 to 12V).
For example, when I set it for 40 Beats Per Minute, every beat will be each 1500 milliseconds. (actually, it´s not digital, so I use a potentiometer to set the TEMPO).
Nice. but I use the metronome with a Transformer or adaptor, conecting to an AC line, and I've found that there are some variatios in the period of each beat. for example: Setting it for 40 BPM, a beat can be at 1520 milliseconds, the otherone at 1505, etc. I mean, there is a variation in the period or frecuency. I think this happens because the DC out is not "CLEAN" I mean the AC is not well rectified. I installed an Electrolitic Capacitor of 2200uf after the bridge rectifier, and I got a little improvement. I installed a ceramic capacitor (0.01uf) between pins 1 and 8 (555's voltage supply)  and another between pin 5 and ground, in order to get more stability. How can I to reduce this variation? how can I to get a better rectified DC output?.
Thanks (please, excuse my english). have a happy new year!!!
EdwardM
Apr 12, 2005
246
Hi Ben
the fact that your circuit works happily with batteries means that there is nothing wrong with it.  I suspect that the transformer/adaptor connected to the AC line is not capable of supplying the current needed to drive the speaker at a sensible volume.
A couple of things to try...
Use a (preferably analogue) multimeter in series with the batteries to measure current or -
If you can borrow/obtain a power supply which has a current and voltage readout, you can verify how much current is needed at 12V, you will then be able to say if the adaptor is 'man-enough' to work.
Hope that helps
Ed
audioguru2
Apr 6, 2004
12,022
I noticed that the polarity of C2 is backwards and it won't last very long.
The output of the 555 is high most of the time.
I agree with Edward that the 12V from the adapter is fluctuating with each beat. Using a 15VDC adapter with a 7812 regulator IC will fix it. ;D
