help with IR2110 chips
Maglatron
Jul 12, 2023
2,025
I can't download the zip files on that site because of my interent connection, Is it possible to download them for me and post them in this thread please Harald Kapp?
Alec_t
Jul 7, 2015
3,821
Its strange that you have no LTS folders in your Documents path. That's where LTS puts working copies , even if you installed the LTS system elsewhere.
Maglatron
Jul 12, 2023
2,025
I don't know, I've made a directory there now anyway, could you download the zip files from the Bordodynov's site and upload them here please? sometime today!
here is everything to do with spice on my computer
Maglatron
Jul 12, 2023
2,025
there's a few more when I search ltspice but nonthing in the documents folder so I've created a folder in documents called LTspiceXVII now I need to have the zip files if you can, thank you!
Alec_t
Jul 7, 2015
3,821
Bordodynov's zip file is 20MB at least. I think that exceeds the upload limit on this site?
Maglatron
Jul 12, 2023
2,025
oh your joking, damn it
can you try? and just to make sure or put the zip in a zip maybe?
does not specify upload limit in terms and rules
bertus
3,877
I think the max size is 5.120.000, wich is about 4.8 Mb
Bertus
Maglatron
Jul 12, 2023
2,025
Okay I found this extension pack what do you recon and what do I do to add thie libraries? see what you think!
  • LTSpice-master.zip
bertus
3,877
This is given in the README of the file:
My personal collection of LTSpice components
Download the zip file and unpack the directory PERSONAL and the files it contains to:
%USERPROFILE%\My Documents\LTspiceXVII\lib\sym\
Unfortunately, github adds a directory named "LTSpice-master" to the zip file.
The "PERSONAL" directory is required because there are references to: "../sym/_PERSONAL/" in the .ASY files.
Files in the _STANDARD directory can be used to replace the components in:
%USERPROFILE%\My Documents\LTspiceXVII\lib\cmp\
standard.bjt (1592 models)
standard.dio (2028 models)
standard.jft (1074 models)
standard.mos (1632 models)
The files in the CUSTOM_SYMBOLS directory can be used instead of the originals (without HP in the filename).
I got irritated because I have to mirror and rotate 90 degrees twice, every time I use the PNP or PMOS symbols.
Also RES and POLCAP have replacements that are drawn as European symbols.
Better do NOT replace the originals in the sym directory. Keep in mind that the original files will be overwritten at the next LTSpice update. For
that reason I added the _HP in the name.
In case you have trouble using these parts, please don't hesitate to create an "issue". I really appreciate to receive feedback from other LTSpice
users
It does not say WHO made it.
Bertus
Maglatron
Jul 12, 2023
2,025
I am getting through it I now have a few libraries, My question how do you add libraries without overwriting the files ie standard bjt dio jft
also can you put in any way that I can access the 20mb file to my collection please
and does it matter then who's it is I have already overwrite it now with no problems, but I do want to know how to get to the files without overwriting the ones I've got
And could you direct me to a mirror of the 20mb zip file perhaps I've been looking but can't seem to find one.
bertus
3,877
Unzip the file and copy the _PERSONAL folder to the sym folder of LTSpice.
The next time you open LTspice it will be shown.
Bertus
Maglatron
Jul 12, 2023
2,025
ok new approach, is there anybody out there willing to cut the files down and upload the parts to be compiled again by myself after getting the information
I really want that file!
So I got a lm7805 but it's not acting as it should I want 12v in and 5v out how do I change the parameters
Maglatron
Jul 12, 2023
2,025
sorry uploaded wrong pucture nevermind it works now I had the in and out mixed up!
Maglatron
Jul 12, 2023
2,025
So Okay now I'vr got my heart set on getting the zzz library any ideas??
is there any way that you can split up the file so that I can download the zzz file please?
I have an idea! unzip and send files separate that would be wicked if you can
Is that possible to do that please?
So I suppose this is where we pause for a bit I need to buy the parts and assemble may take a couple of weeks to get the parts due to limitations on the freedom I have to order and then to work on my project but if in the meantime you do get me a way for me to download the zzz library I would be more than greatfull, cheers people I will update when I have pictures of the circuit board!
bertus
3,877
Here is the file splitted with 7Zip.
Remove the .txt and click the .001 file to unzip the complete file.
(I used the .txt extention to be able to post the files).
I used the lib_bor name to distinct to from the lib file on my PC.
Bertus
  • lib_bor.7z.001.txt
  • lib_bor.7z.002.txt
  • lib_bor.7z.003.txt
Maglatron
Jul 12, 2023
2,025
thank you ever so much you mentioned that you used the .txt extention, do I need to change it back to anything different? thanks again
Bertus
bertus
3,877
As I said, remove the .txt extention, to get the .001 .002 and .003 files.
Bertus
