- Joined
- Nov 17, 2011
- Messages
- 14,317
Rather possibly.this is confusing the dash micro?
Could you run teh front lights through the same auxiliary relay as the rear lights? This would reduce the load on the flash controller considerably.
The dash micro, if it is this particular model, is load dependant. I imagine Ducati were able to forsee the possibility of LEDs replacing the standard bulb and allowed for it in the programming. Have no idea what this actually involves but wondering if you have taken a peek on their forums?
Cheers Jorgo
when you add two resistors of the same type in series the power dissipation is reduced to 1/2 of the dissipation of a single resistor.
However I think you're barking up the wrong tree: the controller is obviously happy with the LEDs when powered by the battery alone. Therefore it is most likely that the issue arises from disturbances (noise) on the powre supply lines when th eengine is running. There are a few possible sources, mainly:
- noise from the alternator
- noise from the ignition
Both noise sources may be reduced by a filter in line between battery and flash controller.
On the other hand an automotive (or motorbike) controller should have been constructed to withstand these common sources of noise.
What about the battery? Is it in good shape? What is the battery voltage with the engine off and waht with the engine on? A worn out battery may have a high internal resistance which in turn may lead to increased noise with the engine running compared to a good battery.
So are you saying it is not micro controlled but rather mechanical/electrical controller?Thanks Jorgo
I have looked in to reprogramming the signals to LED but although it is available on some models it is not on mine!
No problem....either is just fine.Sorry about calling you Jorgo by the way, I actually put Bluejets but my computer decided that it knew better!
