Home assignment
danadak
Feb 19, 2021
1,100
Simplify first :
1) R5 and R6 are in series, so what would the equivalent R in place of them be ?
2) The equivalent R from 2) is in parallel with R4, so whats that new equivalent ?
3) You now have a simple V divider to compute V4......
Regards, Dana.
AnalogKid
Jun 10, 2015
3,055
Once you're done 1 and 2, redraw the schematic in a more conventional manner. Start with the current source to the left, with any resistors directly in parallel with it. Extend the + and - (GND) rails to the right, and then fill in the remaining resistors and equivalent resistors. The + terminal connects to three resistors in the original schematic, so there should be three branches in parallel between the + and - rails.
Once you do that, you can collapse the entire network to a single equivalent resistor across the current source. This gives the current source a terminal voltage. With this voltage and Ohm's Law, you can work out the current through, and voltage across, each resistor.
ak
