How much power can I receive from a FM station
Jeff Liebermann
Re-read the original post.
I don't think this is about powering the radio itself. (i.e, power
supply issues)
The question is about gain for the front end and later I.F. stages.
At least, that's how I read it.
Oops. Y'er right. I thought he was powering the FM receiver with
detected RF. That's what I got out of the title "how much power can I
receive...". For a two sentence question, it shows the (student)
author doesn't really understand that a broadcast FM receiver is
usually run at far more gain than necessary in order to insure that
the IF limiters are well into limiting on just front end noise.
mpm
I'll bet the guy that changes the beacon(s) on the 2k' tower makes a
pretty penny for the job!- Hide quoted text -
- Show quoted text -
I just sent you a cool photo from the good old days.
And actually, climbers and riggers really don't make all that much
money.
(You'd be suprised. Especially when you look at fatality stats!!)
New tower lighting systems use LED's, which last much longer than
incandescent.
It took a while for FAA approvals, but LED lighting is really one of
the better ideas in recent memory. -mpm
Robert Baer
ChairmanOfTheBored said:
Antennas gather microvolts. The resulting power, if one wants to call
it that would be in femtowatts.
It takes a hell of a lot of femtowatts to illuminate a flashlight bulb...
Robert Baer
Eeyore said:
Allen wrote:
You need *variable gain* to cope with the wide range of signals you're likely to
receive. The gain required for any given station is determined by the AGC
(automatic gain control) circuitry.
It seems your question should be "what's a typical minimum signal that's worth
trying to receive" and it's normally given in microvolts not watts.
If this is for ordinary commercial FM 88-108 MHz, I'd look at some typical
receiver specs to get a feel for it.
Graham
Well......for "ordinary" FM use, one never uses AGC, in fact one
wants the IF to limit so as to kill noise.
Robert Baer
Eeyore said:
Jeff Liebermann wrote:
And at 30km which is IME about as far as you want to get for decent FM
reception ~ 42dB
Or ~ -20dBm @ 30km.
Which is 682 mV
Or 21.5 mV @ 30km.
Now scale for those transmitters that transmit rather less power. 100kW is
unknown in the UK for FM. 10kW would result is a signal of 2.15 mV @ 30km.
Graham
Perhaps, but in some cases, i have been over 100 miles away and got a
decent signal.
(how far is it from Atlanta GA to Huntsville AL? about 200 miles...)
ChairmanOfTheBored
money.
incandescent.
I thought that short towers used incandescent, recently adopted for
LEDs, and that taller towers required xenon strobes, and that hasn't
changed.
ChairmanOfTheBored
It would likely take a good deal of them to even get an LED to give off
photons.
ChairmanOfTheBored
decent signal.
Yes, but the tusks are looser in Tuscaloosa.
Eeyore
Jeff said:
Wrong. FM broadcast receivers do not have AGC circuitry (unless
you're trying to keep the group delay through the receiver constant).
There are planty of FM receiver chips with AGC for FM.
Graham
mpm
changed.- Hide quoted text -
It runs the gamut really.
Some towers actually use dual lighting systems.
Strobes during the day, red lamps at night.
Tall towers can certainly be lit with incandescent or LED.
It is not mandatory that it MUST be strobed. (though many are
strobed.)
What is mandatory is they have to be lit in accordance with FCC
requirements, which almost always follow FAA recommendation.
Jeff Liebermann
Graham
Sure. Those are the ones that are used for AM/FM receivers. The AGC
is used for the AM operation, not the FM.
There are some applications where one would want to demodulate AM and
FM simultaneously from the same IF strip. I did one of those in the
AN/SRD-21 and AN/SRD-22 direction finders, where the receiver
simultaneously demodulate the 121.5MHz emergency beacon noises, and
the FM "tone" for the doppler direction finder. An AGC was certainly
required for that.
However, even in the FM demodulation mode, the direction finder needed
AGC. That's because the group delay through the first IF xtal filter
was somewhat dependent on drive level. We had to keep the delay
through the entire receiver stable within 1 degree (out of 360
degrees) over a wide temperature range and wide input signal range.
That wasn't easy.
I scribbled something on the topic in the past. Digging...
<http://groups.google.com/group/rec.radio.amateur.equipment/msg/a23d4b4dc5e090e0>
<http://groups.google.com/group/rec.radio.amateur.misc/msg/e0c4c39d0f0b0b7a>
<http://groups.google.com/group/rec.radio.amateur.misc/msg/c6ff537d9a5476b8>
Anyway, I'm curious. What FM receiver chips have AGC that's used in
the FM section? Just one chip number would be fine. I've been out of
the design biz for far too many years and haven't been paying
attention to the latest component offerings. Extra credit if you can
find a commercial FM broadcast receiver that has an AGC (or an AGC
adjustment) in FM mode.
ChairmanOfTheBored
required for that.
That wasn't easy.
Hmmm... single amplitude carrier with FM modulation schema...
Nope... I can't see where an AGC would be utilized, or have any effect
if it were.
K
kevin93
On Nov 10, 10:30 pm, Eeyore <[email protected]>
Graham
Wrotham transmits 125 kW ERP.
kevin
Eeyore
Not so. I was looking at a Philips chip earlier with a dedicated FM AGC block. Not
shared with the AM section.
Graham
Eeyore
This wasn't the specific one I was looking at earlier but it'll do. It has separate
AM and FM aerial inputs and you can see that both the first stage amplifiers have AGC
(page 2).
http://www.nxp.com/acrobat_download/literature/9397/75011481.pdf
Graham
Eeyore
if it were.
It'll clearly optimise performance. One chip I saw had an AGC range designed for
inputs of 10-600 mV - a 35dB range.
Here's another chip with a really simple FM AGC using PIN diodes. I imagine it's
designed to avoid 'swamping' later stages in the event of high signal level.
http://www.st.com/stonline/books/pdf/docs/8933.pdf
Graham
Jeff Liebermann
(page 2).
Graham
I stand corrected. There is an FM AGC circuit controlling the RF amp
gain in the TEA5777. I hadn't seen that before. I can guess(tm) why.
The digital (DSP) IF filter needs to have its drive level operate near
the maximum input voltage limit or quantization errors will result.
That means that unlike the traditional crystal filter, where the
filter response is independent of drive level, the DSP equivalent is
very sensitive to input level. So, AGC is necessary for all digital
receivers. Yeah, you're right.
I just hate it when I'm wrong...
F
Frithiof Andreas Jensen
mpm said:
On Nov 10, 4:10?pm, Allen <[email protected]> wrote:
Well, you don't care as much about power received as voltage applied
to the receiver's antenna terminals. Another poster asked some other
relevant questions, so I'll wait to hear those answers before
proceeding.
It's posted via Google. you will never hear from "allen" again!
Joel Koltner
Jeff Liebermann said:
That should be
enough to ran a flea power FM receiver.
It is -- the crystal set society guys (http://www.midnightscience.com/) have
plans for a simple slope-detector based FM receiver that requires no external
power (output only goes to a earphone, of course). As I recall they said you
can't pick up anything but stronger stations, though -- not quite as useful as
an AM crystal set, but still a pretty impressive feat.
