How much power can I receive from a FM station
JosephKK
mpm [email protected] posted to sci.electronics.design:
It runs the gamut really.
Some towers actually use dual lighting systems.
Strobes during the day, red lamps at night.
Tall towers can certainly be lit with incandescent or LED.
It is not mandatory that it MUST be strobed. (though many are
strobed.)
What is mandatory is they have to be lit in accordance with FCC
requirements, which almost always follow FAA recommendation.
The other interesting thing i saw is lamp changing fixtures for
various navigational lights. Typical ones had about 6 spare lamps,
and the better ones had a SCADA interface to report lamp changes.
Michael A. Terrell
The RCA TP 66 film chain 16 mm projector would automatically change
lamps while running. The two sockets were on a motorized rail, and when
it detected a good filament a relay would turn off the motor. It
changed lamps so fast that you didn't notice a change of intensity on
the video monitor. OTOH, if both lamps were bad, the projector sounded
like someone was trying to get out, with a jackhammer. :)
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Michael A. Terrell
Joel said:
It is -- the crystal set society guys (http://www.midnightscience.com/) have
plans for a simple slope-detector based FM receiver that requires no external
power (output only goes to a earphone, of course). As I recall they said you
can't pick up anything but stronger stations, though -- not quite as useful as
an AM crystal set, but still a pretty impressive feat.
If there is a strong local AM station you could use a separate tuner
to supply a little power for a preamp.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Rich Grise
I am designing a FM radio receiver. Can anyone tell me show much power
can I receive from a FM station that is in a acceptable range? I need
that value to decide the gain of all the stages. Thanks.
I wish they'd teach you kids to disguise your homework questions
better.
Good Luck!
Rich
donald
better.
Good Luck!
Rich
Be Nice Rich,
we all know the answer is 42.
donald
