How to use LTspice
bushtech
Sep 13, 2016
1,025
I looked inside the battery housing and the temperature contact is not connected to anything
Your sonically welded connections look a bit suspect which started me wondering about whether a repair was bodged.
Do you have these 2 black cables running up the side of the top battery?
ThomasWheeler
Apr 25, 2016
32
I don't, but from your photo I'm not sure where the two black cables are connected to. Could you show me please?
This might be the problem!!:)
bushtech
Sep 13, 2016
1,025
If you look closely at the photos you will see that one black wire comes through the plastic and gets connected to the big pin on the left of the photo. The other black wire stops short and connects to the wide pin closest to you. I unfortunately don't have a photo of where those 2 wires go when they disappear into the battery pack but I suspect they go to a thermistor.
bushtech
Sep 13, 2016
1,025
Unfortunately not. Some of the knowledgeable guys on the forum will be able to help
ThomasWheeler
Apr 25, 2016
32
Can you tell me the writings on the thermistor please? That will help me a lot.:):)
bushtech
Sep 13, 2016
1,025
No writing on it. Just a piece of heatshrinked plastic
ThomasWheeler
Apr 25, 2016
32
I think you can remove the heatshrinked plastic and look inside. Can you do that please?
ThomasWheeler
Apr 25, 2016
32
good news! I put a thermistor in my battery and it works, Hooray. Thank you for all you guys helping me figure out the problem. Have a nice day.:)
GeekGuy
Apr 7, 2016
25
Just for future reference, there are only 2 basic types of thermistors NTC (negative temp coefficient; temp up, resistance down) and PTC (positive temp coefficient; temp up, resistance up) as far as I know.
