Ignition coil driver circuits and experiments
steven2
Jan 19, 2004
1,698
The ignition coil driver circiuts are intresting to but with some modifications to the 12 volts auto ignition coil . and re routing the inputs and hv return efectively gives you more distance between the inputs and hv out this is nessiary in order to preven arcovers , the igntion coil driver circiut itself i biult prototypes easy to fix and with external ic timer and transistor makes it a breeze to repair in the case of a fault . the boxing these are housed in are made from pvc pipes and corner moulding .
My first experiment was a poor mans plasma tube but the best was a simple pencil held to one brass electrodes that put out arcs so thin i was able to cleanly burn clean holes in my skin with virtually no pain at all although the 2n3055 transistor never got hot i was doing good runing a parralell modified 12 volts auto ignition coil unit from the driver circiut to and hope to soon conduct other experiments to share with anyone intrested.
For anyone wanting to know what use could i get from burning clean holes in my skin here is a short list of potential uses .removal of warts .skin cancers burnt off with thin hv arcs this is only from one electrode on the coil , via a pencil.
mixos1
Administrator
Jul 13, 2003
581
This unit has an ignition coil and flyback driver circiut in the one unit.
by Steven
this ignition coil driver circiut prototype works really good with a 12 volts lead acid cell rechargeble battery. and i was able to power up to 3 ignition coils in parralell with this unit
steven2
Jan 19, 2004
1,698
here are the latest pictures of the latest high voltage output ignition foil driver unit in my latest home made pvc circuit box , in this one ive included the 12 volts led indicater circuit to indicate 12 volts input, allso my latest home made ignition coil holder with the coil , and the latest high voltage polarity indicator circuit/ voltage optimizer as i call it , useing microwave oven diodes and an ignition coil driver circuit , and reverse polarity indication circuit , all inetergrated into the whole thing, now the hv return is not being used and this has 2 different hv arc outputs . , the coils positive hv runs into the high voltage modified polarity indicater circuit/hv optimizer, and it s arc is out puted from the second hv polarity indicater/ optimizer, which i normally use as the antanae return . and at the top section of the hv polarity indicater circuit is the second hv output at different potential, now at the front of the circuit box is 2 terminals which should be red but i put red and black as i dident have a second red terminal to use. this exsperimental circuit i beleave works by on the body capacitance thing and the only place the arc will shoot to is my finger, so ill be useing this to exsperiment with , its like a high volatge parasite zapper , but i have some exsperiments to try this on and im confident of finding new ideas for this
audioguru2
Apr 6, 2004
12,026
Run for cover! Steven is close to producing mega-volts! ;D
Hi Steven,
Adding a "condenser" across the transformer's primary might make it even better.
I know, you are thinking about rectifying the mains, and using the 340VDC to power the spark-coil's primary, aren't you? ;D
steven2
Jan 19, 2004
1,698
:audio guru its battery powerd portable and ill try the rectifyer stuff soon see how it goes ,i new you were around this thing you can see somewhere tells you whos online. theres no one in the chat thing just me everytime i go there to see who i can chat to theres no one
ante1
Jan 24, 2004
4,138
Hi Steven,
Have you any of those strobe beacon circuits in your
audioguru2
Apr 6, 2004
12,026
Hi Ante,
Here is a high voltage limitation that we haven't discussed:
The spark coil's core is going to saturate with a particular amount of current through its primary, which is determined by the voltage that is applied to it. Then applying more voltage than that won't make any difference to the voltage of the spark.
steven2
Jan 19, 2004
1,698
:)ante i have got a strobe flasher circuit around but it stoped working after it fell off the shelf a while ago, the most exspensive part on it was the intergrated circuit. i havent botherd to try and fix it yet, just to busy with other ideas, but i did mofify a camera flash unit , by takeing out the 330 volts hv capacitor and adding 2 diodes and a 47uf 350 volts electro, and a mercury switch. and with the flash unit circuitry i was able to charge the electro up just the same and with a push button switch i dump, the voltage right into an ignition coil and got got arcs from that but even with the bolt in the hv output i was getting arcs fly from one terminal and right around the top insulated hv output right to the return the arcs was suposed to come from the top hv out to the negative return but somehow the positive input was acting as a hv output and arcing right around the insulation to the return. the mercury switch was to dump the charged electro voltage when i turn it off, the voltage into the mercury switch would make a muffeld pop and thus shorting out the electro charge, and allso breaks the metal mercury into tiny grey balls that wont combine back to gether any more after a while , ;)
steven2
Jan 19, 2004
1,698
in these pictures i dressed up the front section of this latest high voltage circuit , with bits of white pvc cut and filed to shape to give the front pannel work a bit of a decent look, ive got plenty more high voltage circuits and ill be dressing them up to. i gave this latest circuit another test today with multi meter probes at the 2 single outputs , and as i increased the arc frenquency and applied the tip to my thumb i was able electrically exfoiliate or burn the surface skin layer, with no pain at all. so this circuit has some good uses, in removeing skin and exfoiliateing the surface of the skin and like my mini arc generater made from the small hv circuit from my old astra umax 6005 scanner ,this circuit will will kill any iritateing itch in less than a miniute, by the use of this needle thin adjustable hv arc.
steven2
Jan 19, 2004
1,698
:) tonight i did some more testing of this latest circuit. and first i adjust the frequency of the output arc, that comes out of the probe tip of a multimeter probe i used, i decided to target a small freckle on the skin of my right arm, and after that i viewd it under a projector lense i had laying around and the spot where i treated the freckle , showed the freckle to be completely gone , burnt away and no pain can be felt at all . the projecter lense was dome shaped and i use it for viewing up close . after this i decided to try it on my cup of coffe siting near by, althougfh the lighting in my room wasent to bright to observe any effects , as i held the probe tip just above the surface of my cuppa coffe, i though i could just see this extra thin arc going into my conductive coffe. like a lightening bolt hitting the water, in the ocean .i thought i noticed a slight disturbence, on the flatt surface of my coffe in the cup, ill try it again under better lighting latter
steven2
Jan 19, 2004
1,698
:)audio guru and ante. thanks for the input ill keep yous up to date. or you can view them as i post them :)
steven2
Jan 19, 2004
1,698
:)here is a picture of a modified photo flash unit from a pocket camera, this is the circuit i used to dump high voltage into an ignition coil that gave me big arcs and this was the one where the hv arc was going from one terminal round the hv out then to the other terminal, when it should of come from the hv out to the neg return. the modified camera flash unit i mofified by removeing the photo flash capacitor then i put in a 350 volts 47 uf electro and 2x 1n4007 diodes , one for each end of the electro, and i had a push button not shown that enabled me to discharge the capacitor into the coil, allso i had a mercury switch to discharge the electro when i turne it off, the mercury switch not shown i removed it befor
steven2
Jan 19, 2004
1,698
:)this circuit along with an ignition coil would be ideal for a potent portable stun gun or electrification circuit.
