Ignition coil driver circuits and experiments
steven2
Jan 19, 2004
1,698
:)very unusual teddy, what looks like  2 high voltage outputs is actually one high voltage output and the other the return , and the inputs well the neg is normally allso the return but i see its not , just different . i have a high voltage flyback transformer and it has a hv out and return both at the top  like your coil has them both at the front, keep up the good work tedy lets see ya driver circuit for it , is it the same as the ones i use they are easyer to make to
Tedy1
Feb 20, 2005
29
Im using that driver posted on 2nd page.
I have 25k pots instead of 10k.  :p
PS.
That ignition coil is from this car:
ante1
Jan 24, 2004
4,138
You see, I was almost right it has two cylinders just like I said!  ;D
steven2
Jan 19, 2004
1,698
oh by the way if it takes to long to read all my posts . when exsperimenting with my high voltage output flyback transformer some time back, useing the same driver circuit , a wire come off a pot and the whole circuit went into resonance , acording to what i was told , the flyback would of went into resonance with the mosfet, resulting in super longer arcs , allso at the time i was allso runing the hv outputs through a modified high voltage polarity indicater , i think, anyhow if ya get it right youll be suprized at how far the arcs would go , and the battery i was useing, i think i was useing the high power 12 volts lead acid cell rechargeble battery for it
Tedy1
Feb 20, 2005
29
I built mine based on this scheme:
http://www.electronics-lab.com/forum/index.php?action=dlattach;topic=261.0;id=1708;image
I used IRF530.
steven2
Jan 19, 2004
1,698
i see you use a mosfet instead of the 2n3055 npn power transistor ,  and if ya did use the 2n3o55 tranny , then you will have less chance of looseing that transistor as its not static sensitive like the mosfets are and will last longer . for the mosfet well you will need an mov from drain to source for protection
steven2
Jan 19, 2004
1,698
audio guru ive lernt that from surfing the net that movs are handy for mosfet protection , i was looseing mosfets in the circuit and so  when i put in an mov ive never lost a mosfet since  not bad hey , and even if they was suposed to be protected in circuit then the mov  would provide the extra protection
audioguru2
Apr 6, 2004
12,026
With kilo-volts flying around in arcs, more protection provided by a MOV is good to have.
steven2
Jan 19, 2004
1,698
mosfets are very dear here , and  the npn power trannys are cheaper and i can use the 2n3058 to besides the 2n3055  for the ignition coil driver , the 2n3058 can handle more voltage than the 2n3055 but then i use 12 volts lead acid cell batteries so im satisfied with the great arcs i get from 12 volts , i have no need for any more voltage input than i can allready get
CooperMan
Mar 5, 2006
23
Following on:
"Any electronic device operating at a potential above 10,000 volts should be considered as a possible source of x-radiation even though it was not designed for that purpose. Devices are not considered hazardous when operated at voltages below 10,000 volts because the inherent shielding, such as is provided by the device walls, is generally sufficient for adequate attenuation of the x-rays. Even at somewhat higher voltages, this inherent shielding may be sufficient to reduce the radiation to an acceptable level."
Go see: http://www.abwem.wpafb.af.mil/radiation/index.cfm?id=66&objid=126&cat=Radiation%20Safety
steven2
Jan 19, 2004
1,698
i wonder if kirlien photography be  like  that or not as it uses high voltage to, ive got the plans to make that to
MP1
Dec 7, 2003
3,399
Cooperman,
I do not think the "High Voltage" members need to worry much, unless they are making their own vacuum tubes. According to the 4 requirements in your link for a device to be emitting radiation, requirement #4 is "Low gas pressure between cathode and anode, i.e., a moderately good vacuum."
MP
