interupting a circuit
KTW
Feb 22, 2015
273
What device could I use operate a 9 volt buzzer and then quit or possibly reactivate after 3-5 seconds?
KTW
Feb 22, 2015
273
Thank you Bob, I'm looking at the 555 timer IC.
I've never used one but they're cheap enough to try.
14,317
Dependig on your timing requirements (how long do you want the buzzer to be active, how long is the pause in between, how often do you want the buzzer to sound) you may want to look into a small microcontroller to control the timing by a few lines of software.
KTW
Feb 22, 2015
273
Hi Harald ;
This would be for a garage intrusion alarm activated by a PIR so I would want it to operate intermittently until the PIR stopped sensing which is about 10 to fifteen seconds.
I just don't want a constant buzz.
14,317
Then a 555 in astable multivibrator mode will be fien, no need for a microcontroller.
KTW
Feb 22, 2015
273
Thanks for the assistance, there's lot's of information on YouTube with regard to the 555, should be fun putting it together.
Kevin.
CDRIVE
May 8, 2012
4,960
Hi Harald ;
Keep in mind that you can purchase a inexpensive Sonalert which is a Piezo element driven by an integral oscillator. There are 3 wire models available that can be operated as a constant tone or intermittent beeps (~1BPS) by simply applying power to the intermittent conductor and (-) common.
Chris
KTW
Feb 22, 2015
273
Thanks Chris, I wasn't aware of that.
I'll have a look at them also.
CDRIVE
May 8, 2012
4,960
You're welcome. I used to get them at Radio Shack because they were convenient,... back when they used to stock components.
Chris
