Is it possible to design a 12 volt to 12 volt dc to dc converter
jishak
Oct 31, 2016
Is it possible to design a 12 volt to 12 volt dc to dc converter due to the reason that the voltage across the inductor being zero and hence there is high error in the calculation. It would be good if you could help me with some ideas for this.
Alec_t
Jul 7, 2015
3,821
Welcome to EP!
Assuming you are talking about a switch-mode converter, the voltage across the inductor won't be zero (except at polarity reversal instants in the switching cycle of the converter.
What are you doing that requires a 12VDC/12VDC converter?
jishak
Oct 31, 2016
Welcome to EP!
A hybrid car that runs on a 12 v battery and a 12 volt motor
14,309
Yes. It is called a SEPIC converter. This is a non-isolated topology having a direct connection between input and output.
Why would you want to put such a converter between battery and motor? Can you not connect the motor directly to the battery?
If you need isolation, you'll want a transformer based converter e.g. a flyback converter. The choice of topology depends on the power required, hence Colin's question needs to be answered.
