MrPerfectionest
- Jan 1, 1970
- 0
A guy on mp3car.com is offering up a very compact 12V supply and I am
wondering if the claims he is making are legit. I had contemplated a
similar supply myself but my knowledge was limited to boost / buck
configurations and the high cost of low esr caps to manage output
ripple kept me from taking the idea to fruition. Did I severely
underestimate the power of a full/half bridge or forward converter
setup? He is being mum on what the topology is but from the looks of
it, it appears full bridge to me. What he has posted about it:
volts the output load can be 10 amps sustained, 13 amps peak. It is
optimized for car use and will survive cranking no problem with a 10
amp load.
load!
volts and puts out 12V on the output. With the output between 10-16I just got done designing a new DC-DC power supply that takes in 6-20
amp load.
automotive faston connectors.It measures 1.9" by 3.5" by 1.2" and has 4 standard 0.25 inch
There is a power on LED and a On/Off Jumper.
output range adjustable by a small pot.It can be ordered as a fixed output supply, or as a supply with an
measured my first sample and I measured 97.5% efficiency with a 85-wattSounds too good to be true? It's real. I even surprised myself when I
load!
The supply is 95+ percent efficient over the 8-15 volt range.
