audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
If R3 is 12k like Mixos uses then with a 12V input it will show X12.0 but if R3 is 120k then I think it will show 12.00.
I think the project's translation wrongly says, "zero volts adjustment" for its trimpot instead of, "calibration adjustment" because the trimpot makes a reference voltage for the IC. Then the IC makes the zero adjustment and the trimpot sets the calibration so that a 1M to 12K voltage divider (10V input gives 118mV to the IC) shows as 100mV.
I think the input scaling resistors should be in series. Demonstrating the problem of using separate resistors with a 10.0V input:
1) 1M to 12k divider= 118mV.
2) 1M to 120k divider= 1.07V which is not 10 times 118mV.
Now connect the 12k and 120k resistors in series:
2) 1M to 132k divider= 1.16V which is very close to 10 times 118mV.
The 12k resistor should actually be 12k in series with 1.2k and in series with 120 ohms for a closer 10 times scaling.
