Led display Digital Voltmeter question
Hero999
Oct 28, 2007
2,433
Did you use the negative supply in the end? If not maybe that's your problem.
Bart1988
Mar 15, 2009
10
Yes i did. I'm going to look at the datasheet, see if i'm missing something, and also try out the 100k oscillator resistor.
edit: 100k resistor didn't change anything.
edit2 :
The icl7660 ic is working normal. I did some new measurements :
Battery is 1,58V, icl7660 shows 0,6V. It's a ratio of 2,633 and i can't find any component that's 2,633 times different than the correct value.
Also in the datasheet they specify a 1k trimmer, on this website it says a 20k trimmer. When regulating the trimmer i don't notice any difference, so i'm guessing this may be the problem. If i change to a 1k trimmer i can adjust the reference so it shows the actual value. Or am i wrong?
In the datasheet they also mention a 200mv scale and a 2V scale, what does this mean? Is the measured voltage divided to a 0-2V scale?
The datasheet also says vref should be 1V if the scale is 2V. So for vref to be 1V i have to set the trimmer correct, and then it will show the correct value on the led display?
audioguru2
Apr 6, 2004
12,022
The circuit in the datasheet is correct.
The circuit on this website has many errors.
The datasheet says that the IC has a sensitivirty of 200mV full-scale. It shows how to make it 2V full scale.
The circuit cannot measure its own supply voltage.
Bart1988
Mar 15, 2009
10
I'm going to put in the 1k trimmer this evening (if i have one). that is the only thing that still differs from the datasheet.
This is how i use the voltmeter : In my 30V dc power supply i have a circuit with a 5V voltage regulator that is connected to a transformer. That transformer is connected to another transformer i use for my 30V dc power supply. Because it's galvanic separated it should work i think. I've got another digital meter based on the icl7107 wich i bought somewhere. That one is still working.
The voltmeter i bought broke down because i didn't have a galvanic seperation back then.
edit: I used a 2k trimmer and it didn't change a thing. I still don't know what they mean with the 200mv scale and 2V scale. Does it mean when i use a 12k resistor for 0-200V i should use the 2V scale to get xxx.x reading? So the 2V scale has 2000 steps and the 200mv scale has only 200 steps?
At the moment i have a 470k resistor for 2V scale, a 12k resistor for 0-200V. And the rest of the components is exactly the same as in the datasheet. I have no clue why the icl7107 measures 2,63 times less than the actual value.
edit2: i changed the 470k resistor to a 47k resistor, no change at all. Still a solid 0.6V while it should read 1.58. Someone on posted his project on the eagle website, he had no link between pin 30 and 32 but that's even worse for me. My soldering station also broke down so i'm really getting frustrated. I checked all the connections and i checked the datasheet, i can't find any error in my design.
Bart1988
Mar 15, 2009
10
Did some new tests. I replaced the 12k resistor between pin 30 and 31 with a 10k resistor. Now i get weird results.
So i leave the measuring points unconnected (floating). With the 12k resistor i had 00.0V but with the 10k resistor it rises to 38.xV.
Then i measure the 1,58V battery and it shows 34.xV. Then i switch the polarity and it shows -20.XV. When i unconnect the measuring points and leave them floating the -20.xV slowly decreases.
I'm guessing my capacitor/resistor combination is faulty. I'm using a 103 (10n) ceramic disc capacitor and a 10k(9,98) resistor at the moment.
audioguru2
Apr 6, 2004
12,022
The circuit in the datasheet does not have a resistor between pin 30 and pin 31.
I guess it is part of an input attenuator to reduce the sensitivity from 200mV to 2V.
Bart1988
Mar 15, 2009
10
I noticed that too, but on this site they say you can adjust the scale with a resistor between pin 30 and 31. That's why i used a 12k resistor for 0-200V.
edit: so i took out the fixed resistor between pin 30 and 31 and switched it with a trimmer. Turns out it needed to be 31,5k. Strange but i knew something was wrong with the resistor/capacitor combo.
Thanks for your time and help.
I still have one more question though. I have a second meter wich i use as an ampere meter. But does it need and extra power supply different than the one supplying the voltmeter? Now i have a transistor that goes to a 30Vdc power supply and to another transistor. That transistor goes to a 5V and -5V power supply. Can i use that supply to power both meters?
Thanks in advance.
edit: This is getting really frustrating. I'm getting a feeling this icl7107 chip is crap. First when the multimeter was supplied by my 30vdc variable power supply it measured the 1,58V battery perfectly. Now with the icl7107 voltmeter in the 30vdc power supply it shows 3V when i regulate from 0 to 3V. The leds don't go beneath 3V for some reason. It's so weird.
I did the trimmer back to 11k so the voltage division is set for 0-200v. I connected pin 32 to GND as recommended by this guy http://www.electro-tech-online.com/electronic-projects-design-ideas-reviews/109313-icl7107-voltmeter-sensitivity-2.html#post897696
I removed the 47k resistor and put back the 470k resistor for 2V full scale. Still didn't work.
So tomorrow i'm going to put a 10k trimmer instead of a 2k trimmer to regulate the reference voltage. I couldn't get it higher than 315mV and it needs to be 1V. If that doesn't work i'm going to switch the cap at pin 27 for a bigger one (1
Bart1988
Mar 15, 2009
10
I fixed it using this datasheet : http://www.datasheetcatalog.org/datasheet/TelComSemiconductor/mXrtrqt.pdf
I used the top right schematic on page 19. The only thing i added was a trimmer over pin 30 and 31 so i could finetune the voltmeter. Now it works perfectly, it's on par with my DMM. I'll post some pictures tomorrow when i got some time.
Next thing i need to fix is the shunt for my ampere meter. Does it need an extra galvanicly seperated power supply next to the one of my voltmeter? Or can i use the same?
I also put some knobs on the potmeters, but i think i broke one of them by using too much force. When i turn it it goes to 21.1V when i turn further it goes back to 15V. Before it regulated to 31V. I'll look into it later. I'm glad my voltmeter works finaly.
bean1028
Jan 30, 2010
7
I know it's not as much fun, but Harbor freight sells 3 dollar dvom's, PERFECT for the 0-30vPSU. I got one and stripped it, the signal wires even have ring terminals already attached to them which you can connect to the back of your output terminals. The only thing you need is a 9v supply (which you can easily acheive with an lm317), and the cable for the LCD is that square rubber thing, but I just used it anyway because the sub-board it was mouted to fit perfectly in the front of my psu. I cut a hole for the LCD and it look just like it's supposed to be there, and there was no designing/re-designing schematics and boards. You can also put a switch to use your leads for power on one side and on the other side of the switch have the outputs routed to only the dvom, turning the ordinary PSU into a PSU with built-in 600v DVOM.
audioguru2
Apr 6, 2004
12,022
LCD digital voltmeter modules are inexpensive and work well.
But people still want the old-fashined power-hungry LED digital voltmeter circuits.
Hero999
Oct 28, 2007
2,433
LEDs are bright and can be seen in the dark, LCDs can be hard to read in difficult lighting conditions.
Who cares about power dissipation? It's not like it's being run off batteries.
audioguru2
Apr 6, 2004
12,022
The datasheet for the ICL7106 for an LCD display and the ICL7107 for an LED display describes the problems caused by heating for the LED one.
The heating causes an offset voltage that could cause the circuit to be out-of-range where most of the LEDs turn off which causes an opposite offset voltage then the IC becomes an oscillator.
They recommend using an external reference voltage to minimise the problem.
mendimano1
Dec 31, 2008
59
when im clicking on a links posted for yhis project im geting Error 404 file not found.
Hero999
Oct 28, 2007
2,433
The project has been moved from one place to another on this site. I've edited the link in the first post of this thread.
http://www.electronics-lab.com/projects/test/001/index.html
mendimano1
Dec 31, 2008
59
mixos said:
First of all I attach here the FIXED SCHEMATIC (22-2-04):
I attach also two sample power supplies for this voltmeter:
Hope this one solves all previously mentioned inconsistencies. Also the schematic at the project's page is updated:
http://www.electronics-lab.com/projects/test/014/
blacksheep : To measure the current flows a load you use a small resistor in series with the load and you measure the voltage drop on it. Then with ohm's law you calculate the current pass throught the resistor and throught your load. You can't easily measure the current right away. So you can use the same circuit to measure the voltage drop across a resistor. For more info on how to do this see the pdf file i indicated previously.
I dont have accses to attachments...why?
mendimano1
Dec 31, 2008
59
Hi, im intend to build 2 LED voltmeters according to the schematics an PCB posted by M.P, i will use to measure the voltage and curent of Power supply wich i have build acording to the schematic at this site and modified to 0-30 volts 5 amps version, please if anyone can give me some calcuations for resistors value im intending to use 0.27 ohm resistor as a shunt to measure the current, ( R7 of P.S)
i have  attached the PCB and schematic in eagle format of LED voltmeter. can someone tell me how much should be the value of R3 for 0-30 volts and how much sholud be the value of R3 for voltage 1.35 volts wich i have calculated  for voltage drop across the 0.27 ohms resistor sow my panel voltmeter shows 0-5 amps current flow of P.S
audioguru2
Apr 6, 2004
12,022
The voltmeter project still has a lot of errors. Look at the datasheet of the voltmeter IC for corrections.
I think the voltmeter must be powered by a power supply that is separate from the power supply that it is measuring.
mendimano1
Dec 31, 2008
59
Dear guru my power supply transformer has a 2 pair of windings 15-0-15 volts (30 volts 10 amps) and
7.5-0-7.5 volts (  15 volts and 2 amps) I'm intend to use this second winding to supply the LED voltmeters ( with rectifier bridge 4X 1N4007) also in a circuit that I'm going to use is an ICL7660 as a negative voltage converter (-5 volt). Please see attached schematic and PCB layout, i think until now this is the best and modified schematic, i hope doesent have any errors.ICL7106-7_Eagle_Files.zip
  • ICL7106-7_Eagle_Files.zip
audioguru2
Apr 6, 2004
12,022
I like new LCD not old LED voltmeters. I never use a voltmeter in the dark so the LCD display has good visibility.
mendimano1
Dec 31, 2008
59
I agree with you guru, (  you got a good point with working ina a dark ;D) but i have only 7 segment LED displays, anyway thank you very much for your help and advice
