Guest
- Jan 1, 1970
- 0
A couple questions if I may...
I'm just starting to get into electronics and this will be my first project. I was hoping someone could lead me in the right direction. I'm working on a similar project which can be found at
www.uoguelph.ca/~atoon/circ/vps.htm
1) I have a 10,000uF cap on hand that I would like to use to give me good, low-ripple properties. With this (if I can use it) should I use a 6A, 8A or 10A bridge rectifier. Do I need to change any of the resistance values or for that matter and of the circuit? I plan on going with a 3W, 1.8K R1 due to predicted heat issues and for more reliability.
2) The bypass transistor looks interesting to me (saw this in the LM317 PSU post in the Projects Q/A forum). What exactly does this accomplish? Is it worth while putting it in and if so how would I connect it in the circuit?
3) I have a 24V ---> 2A centre tapped transformer I plan on using. To be honest I plan on working on circuits below the 21V mark so I'm not to concerned about the smaller voltage at the output. Why does everyone want a 24VDC and higher output voltage? How do I figure out my theoretical output (both V and A) using the above transformer?
4) I plan on making an additional circuit with a smaller transformer in paralell at the 120VAC input. This will be used to power a small muffin fan to blow across the LM317 heatsink and transistor (if I go this way).Hopefully this helps disipate the heat generated at the IC.
5) Where the 220 ohm resistor is, he talks of using a 240 ohm resistor. Which is better?
6) I plan on adding the two diodes to the output of the IC to drop the voltage down to 0V, if needed. (I see this being useful when driving a motor or if you have a circuit that needs a 0 reference).
If anyone has any upgrades or suggestions I'd love to hear them.
Thanks for all your help in advance.
Jay
Jay
