LM317L Voltage drop with load
jgauthier
Mar 22, 2013
63
Hey Everyone,
I am struggling with an LM317L (TO-92) which seems to be having a significant voltage drop.
Let me set the stage:
12V coming into the circuit, that is then going through a 5V regulator. I have a steady 5V.
After that, the rest of the circuit is turned on with a mosfet.
At this point I have about 4.75 volts. Then into the LM317L, where I need 3.3V. I do have 3.3V (or 3.4V), until I apply a load, even a simple LED. Then voltage drops to an unusable 2.8V or lower. I am not sure why.
I have attached the circuit diagram of the LM317L part. I appreciate any pointers.
Thank you.
14,306
What is your load current? Figure 4 of the datasheet will tell you that at 500mA and 25°C you need an input voltage that is at least 2V higher than the output voltage. In your case that would be 5.3V. But you only have 4.75V. The regulator will not be able to operate in a stable manner.
A low drop regulator, e.g. the LT1086 with only 1V votage drop will be better suited.
jgauthier
Mar 22, 2013
63
Thanks! I see that even with a 20mA load the dropout voltage is 1.5V, so yeah. I will try another part!
CDRIVE
May 8, 2012
4,960
Along with what Harald said you should be aware that your caps don't appear to be grounded. In your schematic, that is. Your Cad program uses dots where connections are made. I know this because I see them in your schematic but both negative terminals of both caps appear to just rout over the ground node with no dot to indicate a connection.
Chris.
jgauthier
Mar 22, 2013
63
Wow, nice catch! I just threw that together to demonstrate what I was working on, and the caps are connected to ground on the physical circuit. :)
CDRIVE
May 8, 2012
4,960
Yeah, I figured that it was just the schematic. ;)
Chris.
